20 Most Recent Bosch Axxis WTA4400 Dryers Questions & Answers
Bosh axxis filter. how do i clean it? soap and
First of all the item I referred to in my question is actually a heat exchanger located below the dryer drum.
The maintenance man in the condo said remove it and clean it with soap and water. I did have a garden hose with a sprayer so I used the bath tube to give it a good cleaning.
It now looks clean and I cleaned the housing where this part is located with vaccuum and wet cleaning.
jtoolan 6-12-09 7:45 AM
4/7/2020 5:57:24 PM • Bosch Axxis... • Answered on Apr 07, 2020
The back of the new dryer has a foam like pad
It is a heat insulator
6/13/2019 12:08:06 AM • Bosch Axxis... • Answered on Jun 13, 2019
2answers
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer. I have the model service manual though HERE If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
11/22/2014 10:07:30 AM • Bosch Axxis... • Answered on Nov 22, 2014
0answers
Steps by step to changing motor
Take the old one out and pay attention to the steps. Reverse the steps to replace the new motor.
5/22/2014 1:12:42 AM • Bosch Axxis... • Answered on May 22, 2014
3answers
Our Bosch Classixx Condenser Tumble Dryer works
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
12/25/2012 9:43:09 AM • Bosch Axxis... • Answered on Dec 25, 2012
My bosch dryer is not
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
8/18/2011 5:38:44 AM • Bosch Axxis... • Answered on Aug 18, 2011
How to replace selector switch (timer)for bosch
Open the top cover holding with three screws. Open the console by opening three screws.Than open timer holding plate(four screws).Timer is attached with two screws with plate.Take the nob out and reverse the procedure.
Thanks.
8/2/2011 1:47:28 PM • Bosch Axxis... • Answered on Aug 02, 2011
2answers
Bosch classixx condenser drier
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
7/17/2011 5:11:58 PM • Bosch Axxis... • Answered on Jul 17, 2011
Dryer won't start after selecting cycle choice.
Does the dryer make a humming sound when you try to start it or is it completely silent?
1/31/2011 1:47:12 AM • Bosch Axxis... • Answered on Jan 31, 2011
Dryer runs but no heat and clothes stay wet and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
1/15/2011 4:49:50 AM • Bosch Axxis... • Answered on Jan 15, 2011
Dryer heating then tumbler stops after 10min but
IS THE DRYER A SENSOR DRYER IF SO TRY PLACING A JUG OF HOT WATER INTO THE DRYER, BUT DO NOT EMPTY THE WATER IN THE DRYER, JUST LET THE STEAM OFF THE WATER OPEN THE SENSOR HOOVER DYERS HAVE THIS PROBLEM TO
1/8/2011 9:46:40 PM • Bosch Axxis... • Answered on Jan 08, 2011
This is a Bosch electric
are you sure it is the element, and yes repairing it is a whole lot cheaper:
http://shop.ebay.com/i.html?_nkw=heating+element+dryer+bosch&_sacat=0&_odkw=heating+element+dryer&_osacat=0&_trksid=p3286.c0.m270.l1313
this should assist you:
http://www.espares.co.uk/advice/tumble-dryers/a/9/1344/how-to-replace-the-heating-element-assembly-o.html
12/4/2010 12:34:56 AM • Bosch Axxis... • Answered on Dec 04, 2010
The lint filter light continues to come on and
check the inlet filters first and then the out let hose the dryer needs to breath in a lot of air so if any of the inlets or out let pipes are blocked that could put this light on
8/27/2010 11:28:14 PM • Bosch Axxis... • Answered on Aug 27, 2010
Bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
7/4/2010 3:48:41 AM • Bosch Axxis... • Answered on Jul 04, 2010
2answers
Bosch Dryer, I have determined that the drum belt
If the belt is not slipping and it has good tension on it still, I would not spend the money right now to replace.
6/3/2010 3:41:21 AM • Bosch Axxis... • Answered on Jun 03, 2010
No heat
the first thing to check is that you have 220VAC at the plug. If one leg of the circuit drops out you can have this symptom.
4/20/2010 2:27:25 PM • Bosch Axxis... • Answered on Apr 20, 2010
Dryer runs, but no heat
take the back panel off and look at the heating element can there is a thermal fuse that has a small reset button on it. push this in if that does not work then you need to check all the thermal fuse as well as the heating element for continuity if there is any of the above mentioned items that do not have continuity then replace the one that does not have anything
3/13/2010 4:44:23 PM • Bosch Axxis... • Answered on Mar 13, 2010
Bosch Axxis WTA4400 Dryers Logo
38 questions posted
Top Bosch Dryers Experts
vince
NOEL
NOEL
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dryers
  • Bosch Dryers
Most Popular Question
our bosch classixx condenser tumble
  • Dryers
