20 Most Recent
Sharp AR-BC260 Color Copier Questions & Answers
Sharp m165 error h4-00 give solution
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
H5-01 without technician assistance
H5-01 means repeated paper jams on the Sharp photocopiers. Once the paper jam is cleared properly, you need to clear the error condition. Put it in 'Copy' mode. Press on the keypad: Related Groups. Printers, Copiers, Scanners &
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
F2 error
Without the sub code hard to say, but check the thermistor in the fusing section. F2 also refers to toner empty and some other issues.Try to get the sub code it will helps. In case you need the service manual you can get it from http://fixmfp.com
Sharp m165 showing error H4-00
H4-00 relates to the fusing unit not reaching the desired temperature. This could be due to a heat lamp or thermistor failure. I would recommend calling your local service engineer. hope this helps.
Code H5-01
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arbc260.pdf
Sharp MX-M450N getting F2-00 error
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
We cannot scan to email from our Sharp AR-M237
Model AR-M257 - I have several Sharp MFP devices at different locations and
all are set up to scan through our email server using a special account I have
just for this purpose. I have all of
them setup using the external IP address of our Exchange server (not its name
or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP
addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this
one. I was getting the following error
when trying to send a status message (under Log) from the device to my email
account as a test: [error 973] incorrect
format for primary smtp server. And when
I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and
DNS but as I was trying anything I could to get it working I went to mDNS under
Services and it was enabled. I disabled
it and then I could get a status message to be sent to me and we could send a
scan through our email server.
