20 Most Recent
Sharp ENERGY STAR AF-S60FX Thru-Wall/Window Air Conditioner Questions & Answers
Turning off
It is a code that means you need to clean the filter. There is a whole sequence to reset it after you have cleaned the filter. google Sharp E1 code reset and you will find instructions, or call sharp customer service and they will email it to you. 1-800-237-4277
Shuts off and flashes E1
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
The air conditioner runs for a little while then
This may help
1) Disconnect power
2) Hold down on/off while plugging cord back in, til you hear a beep
3)unplug again
4) plug in
5) start a/c
Hope this helped Tim if not then I would call the 1-800-237-4277
Help
go to sharpusa.com and click on support, they have all the model airconditioners and all the help. its in pdf format and i dont know how to paste the info. really easy problem to fix.
Basically, tells you to make sure air filter is clean.Unplug from wall, then hold Power/on/off button down and plug unit in wall. press Power/on/off button until you hear a beeping sound(approx 5 sec) then disconnect powerplug from wall. plug back in and start your ac again. it should work!
If this dont work try the same thing but by pressing the Mode button and same kind of operation as above, but the unit will start to operate after you press mode and herar the beeps. turn off by pressing On/off button. then start as normal. if you cant get it go visit the website.
Sharp comfort touch keeps turning up to "hi" fan repeatedly
Clean the air filter: A dirty air filter can cause the unit to malfunction. Remove the filter and clean it with a soft brush or vacuum cleaner. If the filter is damaged, replace it with a new one.
Check the thermostat: Make sure that the thermostat is set to the desired temperature and mode. If it is set to "fan only" mode, the unit will not cool the room.
Inspect the evaporator coil: The evaporator coil can become dirty or frozen, which can cause the unit to malfunction. Check the coil for dirt or ice buildup and clean it if necessary.
Check for obstructions: Make sure that there are no obstructions blocking the airflow around the unit, such as curtains, furniture, or other objects.
Reset the unit: Turn off the unit and unplug it from the power source for a few minutes. Then plug it back in and turn it on again.
If these steps do not work, you may require a technician.
My Sharp AF-Q100RX AC won't switch to High fan!
- The fan won't start even though the AC is on.
- The fan won't stop, even when you shut the AC off.
- The fan turns on, yet the blades are rotating very slowly.
- There's a rattling noise coming from the condenser unit when the fan is turned on.
WHY DOES MY SHARP A/C KEEP SHUTTING OFF?
If the circuit breaker is the proper size for the unit (see the manufactures installation instructions), then the high current tripping the breaker is most likely a failure of the compressor. It is stalling causing high current. You may be on the verge of having to replace a worn out unit.
If the unit is more than 7 years old, you may hav reached the end of it's life.
