20 Most Recent
Sharp Projector lamp Projector Lamp Questions & Answers
Replaced new lamp in sharp pg-d3050 projector, but
then ,check the lamp or lamp ballast (integrated with the powersupply)
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
My sharp XV-Z90U was working fine except that it
mainboard is failed
Have a nice day!
Jerry
Lampdeng Limited
How do you reset the
There are two common methods to reset the lamp counter on these
projectors: Method 1: - Press the decrease volume button on the remote and then the
increase volume button within 3 seconds. - The LED light on the projector will turn green. - Turn on the projector. Method 2: - Turn on the Projector. - Open the standard menu using the remote. - Then select "Setup" or "Service" depending on your
projector model. - Then select "Reset Lamp Timer" hope this solution has been helpful?
I bought a new lamp for my sharp XR-11XC.
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Recently I was using my xv-z90u, I started the
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Projector image burn (retention)
first off, make sure you got the right lamp and it's from sharp, not a "lamp store". the quality varies. it could be burning hotter than it's designed for. second, you may need to reset the setting to factory default (through the menu options). third, you may need flash upgrade. you'll need to contact a sharp service center for that.
Our Sharp projector Model PG-B10S is Flickering
the flickering could be the lamp, but as for the bluring: if it's pixelated, it's resolution. make sure the computer and projector have the same. if it's not pixelated bluring, it's an optical problem. either the lenses are dirty or misaligned.
