20 Most Recent i-mate JASJAR Smartphone Questions & Answers
I have i-mate jasjar but when i connect to desk top computer it won't appear on sreen or if i want to transfer nothing appeared on desk top computer
Have you connected it to the PC before? If not then you will need to install Active Sync from Microsoft. I assume that your phone is running Windows Mo
1/18/2015 10:16:04 PM • i-mate JASJAR... • Answered on Jan 18, 2015
My imate jasjar wifi cont
my i-mate jasjar wifi cont connected please send setting my id ([email protected])
12/23/2012 6:12:26 PM • i-mate JASJAR... • Answered on Dec 23, 2012
I-mate JASJAR pu10 Smartphone windows mobile 5.0 data mixing, how can I get same windows to install?
...mda pu 10 to connect t computer hi where can i find the driver so can connect my foon"mda pu10" so ican take...
8/21/2012 5:29:04 PM • i-mate JASJAR... • Answered on Aug 21, 2012
2answers
I-mate jasjar does not align by tapping on different positions
1st thing to do is that, if you know how to disassemble your jasjar try to align the four connections behind the LCD or try to resolder it. If still not working, 2nd thing to do is you must change your Touch screen sensor. If you know how to change the sensor it's much better but if not, then you have to go to a mobile technician. Hope I help you with my idea on your problem there....
1/27/2012 7:00:53 AM • i-mate JASJAR... • Answered on Jan 27, 2012
I have a i-mate jasjar.
align screen
9/22/2011 9:01:43 AM • i-mate JASJAR... • Answered on Sep 22, 2011
I want to repair my
fanite fala........
9/20/2011 3:54:05 PM • i-mate JASJAR... • Answered on Sep 20, 2011
I formatted my imate jasjar.
Perform a hard reset to return it back to original state....... To perform a hard reset on a Cingular 8125, I-mate Kjam, T-mobile MDA, or other similiar device:
  1. Hold down the communications manager button (top left) and the Voice activation button (top right).
  2. While holding down those two buttons, use the stylus to hold in the reset button for a couple seconds.
  3. Release the stylus but not the other two buttons. After a couple seconds, a black screen when come up asking you to press send to continue.
  4. Release the communications manager button and the Voice activation button and press send (green phone button)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
8/24/2011 12:40:38 PM • i-mate JASJAR... • Answered on Aug 24, 2011
Hi, When power on my I-mate
1st SOLUTION SHOULD BE SOFTWARE IF KEYS SOUND NOT HEARED, 2nd , IF YOU CAN HEAR KEY SOUND YOU CAN ONLY CHANGE LCD AFTER CHECK LCD CONNECTOR,
4/21/2011 4:10:18 AM • i-mate JASJAR... • Answered on Apr 21, 2011
My I mate jasjar suddenly
i think its battery fault u can change it and try.and reset it.
2/22/2011 4:25:35 AM • i-mate JASJAR... • Answered on Feb 22, 2011
4answers
The battery went flat in
Welcome to Fixya
Try to drain the static energy of the board. Take out the battery and unplug the power adapter. Push and hold the power button for 15 secs. Put everything back in then turn on the gadget.
Thank you for using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1/24/2011 6:46:32 AM • i-mate JASJAR... • Answered on Jan 24, 2011
20answers
Airtel live settings for china mobile
Im using china Blutooth y690 & have airtel sim but it does'nt accept the settings of airtel live pls tell me how to configure settings mannually the phone has two menus i.e. wap profile & data setting
8/7/2010 5:22:20 AM • i-mate JASJAR... • Answered on Aug 07, 2010
How to install this phone to my pc ?
Its very simple, connect yur phone to the PC using the Usb cable connection or via BT.
Use ActiveSync & Windows Mobile Device Center
and then connect and Sync.
Its easy as that.. Enjoy.
6/23/2010 5:33:57 AM • i-mate JASJAR... • Answered on Jun 23, 2010
I mate original rom for jasjar
hi there,
i need the origanl rom too.i lost my rom and my fone is just showing me balck secreen and no display as i did hard reset but in vain. pls pls help me if you find any link where i cold get the rom for my jasjar.
my id is
[email protected]
thnx
raza
6/23/2010 3:34:27 AM • i-mate JASJAR... • Answered on Jun 23, 2010
Window problem
Your device is, most probably, in bootloader mode, state in which it is starting to be fllashed with a new ROM. A simple press on the reset pin, with the stylus pen, should suffice to turn it back to life. Othewise, I'm afraid you'll have to hard reset your device. You, most probably, know that a hard reset will delete all the applications you have installed, as well as your personal data and settings. Hope you have a recent backup, to be used afterwards. Anyway, to hard reset your device, open its screen to reveal the hardware keyboard. Then, press and hold both softkeys on the keyboard (the ones marked with '-'), and, whilst keeping them pressed, briefly press the reset pin with the stylus pen. Release the softkeys when a screen asking for confirmations comes up. Confirm the procedure by pressing 0 (zero).
Hope you are able to sort your problems out.
Regards, Carlos
6/18/2010 10:28:54 PM • i-mate JASJAR... • Answered on Jun 18, 2010
My hand-set i-mate(jasjar) make some problem 2
Go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab' and set the 'My network card connects to:' dropdown menu to 'The Internet'.
Hope it works for you.
Regards, Carlos
6/11/2010 4:03:34 PM • i-mate JASJAR... • Answered on Jun 11, 2010
I have an i-mat jasjar 900,when switch on then
You have to tap the exact center of the '+' symbol with the stylus pen 5 times: on the center and on each corner of the screen. If you miss one of them, the process will be restarted.
Just my 2 cents... Carlos
4/13/2010 2:36:53 PM • i-mate JASJAR... • Answered on Apr 13, 2010
2answers
China N5800, I WANT THE airtel live GPRS settings
call to 121 and get the code for downloading settings and then get the settings and use the net
4/6/2010 10:36:46 AM • i-mate JASJAR... • Answered on Apr 06, 2010
3answers
I have i mate jasjar i am trying to use wireless
the spesific wireless you are connecting to is protected and requires a encryption key, like to open a door.
Or if you know that the network does not have security inplace then leave it Blank, if it keeps asking for a key, then its a protected network, find another one that is not protected.
3/25/2010 7:17:11 PM • i-mate JASJAR... • Answered on Mar 25, 2010
i-mate JASJAR Smartphone Logo
114 questions posted
Popular Products
Top i-mate Computers & Internet Experts
ExpressFiX
ExpressFiX
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • i-mate Computers & Internet
Most Popular Question
mate jasjar pu10 smartphone windows
  • Computers & Internet
