make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Test all power and data leads that attach from motherboard to your hard drive IDE SATA
make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat 40 pin ide it will be the first to fail
check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it
restart your computer the found new hardware wizard should activate
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error also check the keyboard for secure dust free connection ps2 and or usb hope this helps
Required software and components for Internet Explorer 9 Installation
The installation of Windows Internet Explorer 9 includes the installation of additional prerequisite software and components based on the destination operating system.
Internet Explorer 9 will try to automatically install prerequisite software and components. If the installation of prerequisite software and components does not succeed
Internet Explorer 9 will not be installed. If this problem occurs you must manually install the prerequisite software and components that are described in the following sections. Note Internet Explorer 9 might not automatically install prerequisite software and components if the installation of other updates is in progress or if a system restart is pending.
To determine whether installation of updates is in progress or a restart is pending, take the following action for your operating system:
On Windows 7, click Start, click Control Panel, choose Large icons or Small icons from the View by drop-down list, and then click Windows Update. On Windows Vista, click Security in Control Panel, and then click Windows Update.
If there is an update installation in progress allow the installation to complete before you try to install Internet Explorer 9.
If updates have been installed but the system has not yet restarted, restart your computer before you try to install Internet Explorer 9.
hope it helps
If
you need to install drivers.
Always
get your drivers and specific software from the manufacturer of your
Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the
manufacturer's
web
site,
usually one is able to download if available, by model
number,
All
available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing.
This is the best way of ensuring up to
date drivers for your system and they are free of charge!
I hope this helps
60 questions posted
3,409 Questions
2,234 Questions
1,799 Questions
796 Questions
724 Questions
