20 Most Recent
Acer Veriton 7600G PC Desktop Questions & Answers
Windows Media Player cannot play the file because there is a prob
If this is the promblem with any music player in your computer than their is no sound driver installed or some sound files are missing to check if the sound driver is installed you can open the control panel---->sounds and check if the driver is installed if it is not you must install it using the motherboard CD that came along with your Pc
The volume in control pannel is disabled
Go to your system devices on your control panel and enable the sound board. When you click properties, it will show you that it is disable. Just "enable" it there.
I can not find drivers
on Acer website can find drivers for windows xp. Windows 7 will probably recognize all system components and update drivers through "Windows update"
Habe einen Acer Veriton 7600 G der sich einer
Hallo,
Also wäre nett wenn du ihn saubermachen würdest. Viel zu viel staub. Es kann aber auch sein das sich dein Ventilator nicht mehr dreht, weil er total verstaubt ist oder ausgebrannt. Um dies zu testen, bitte den PC ausschaulten, öffnen dann den Ventilator mit dem finger drehen und sehen ob dies einfach geht. Wenn er sich nur sehr schwer dreht oder garnicht, dann muss er ausgewechselt werden.
Abschalten, ist einfach weil der Ventilator den CPU nicht genügent oder garnicht abkühlen kann.
I cannot boot my pc
You first need to try and start it in safe mode. Usually you can get to it by pressing F8
Other computers may have a different button, so if F8 doesn't work then press the other F's
Also, does it give you the Blue Screen of Death?
How do u clean out java
i use ATF Cleanert, it empties all the junk files you collect while using the internet. It's free, very fast and easy to use. I use it EVERY time I close my browser, and always run it twice or until I get the message , "no files were removed" . it can be downloaded free here :
www.atribune.org/ccount/click.php?id=1
One of the things it cleans is the JAVA cache
regards..
Copy windows vista from my laptop to my acer pc
you can not just copy vista. you would need to get an install cd of vista and install it onto the pc. this still may not fix your internet problem as there is no guarantee that vista will even have the drivers for your pc components.
ACER Veriton 9600G Black out
Are you getting any light on the Monitor led? What is the color of light?
You said you are getting a beep. Its a long beep or a short beep?
Warning your chassis has been opened
Hi need help asap.
I opened my acer desk top box to clean dust out and now has warning chassis open.
I cant access the bios or anything else. Does someone have a suggestion????
Panicking
