20 Most Recent Panasonic Viera TC-P50S2 50" Plasma TV Questions & Answers
Hi, I have a Panasonic TC-P50S2 Viera Plasma TV that has died. Basically Iwant to know if this is worth the time and $$ to repair? Are parts available for me to DIY this?
Good make and it is an HD model with good reviews. It is about 10 years old. It really depends of if fancy a new one or not. I don't advise against home television repair. We see about 10 questions a day here of people who replace boards and still have a non working television. You need the experience and the test equipment.https://www.fixya.com/support/r29790007-repairing_own_televisionhttps://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00wu8OXxqxE3KlHGB8dHyRz5U2nAQ%3A1609953102652&ei=Tu_1X9uWJ4-ytQWRk6-ACA&q=Panasonic+TC-P50S2+Viera+Plasma+review&..
1/6/2021 5:17:27 PM • Panasonic Viera... • Answered on Jan 06, 2021
2answers
Panasonic Plasma TV TC-P50S2 10 blinks
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
6/25/2018 8:15:42 AM • Panasonic Viera... • Answered on Jun 25, 2018
My 2010 Panasonic Viera tc-p50s2 TV turned off and the power light started blinking 10x's. Why? Can you help?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
11/8/2016 3:50:06 PM • Panasonic Viera... • Answered on Nov 08, 2016
Panasonic tc-p50s2 10 blink error
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
3/13/2016 6:18:05 AM • Panasonic Viera... • Answered on Mar 13, 2016
2answers
I have tv Panasonic TC-P50S2. WHEN I PUT POWER MY TV HAVE 10 TIMES BLINK. WHAT WRONG MY TV AND WHAT BOARD I HAVE FIX? THANKS!
hope it help you body of mine had a similar problem he remove the back cover it was full of dust spray air it work for one year and did it agan in november and still work notice there lots of screw to remove
4/8/2015 11:25:12 AM • Panasonic Viera... • Answered on Apr 08, 2015
0answers
Panasonic viera not working 10 blinking lights
use these charts to diagnose the problem.683e95d8-7018-4fe7-8dc3-ea20b0947a03.jpg46e288c4-63e2-49f6-a036-2cbdecb920d9.jpg
4/18/2013 1:31:36 AM • Panasonic Viera... • Answered on Apr 18, 2013
2answers
What board should I change
Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
10/5/2021 11:51:02 AM • Panasonic VIERA... • Answered on Oct 05, 2021
I have a Panasonic Viera TV, but whenever I press aspect on the remote nothing happens.
Could be a bad remote, that button isn't responding
8/22/2021 1:01:06 PM • Panasonic VIERA... • Answered on Aug 22, 2021
Panasonic Viera tc-p65s2 - 7 blinks, won't turn on
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The pop is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
4/14/2018 8:10:48 AM • Panasonic VIERA... • Answered on Apr 14, 2018
I need to program a Rogers digitial box to my viera t.v.
That probably won't work. You'll have that problem until you get a new TV.
2/13/2018 12:37:40 AM • Panasonic VIERA... • Answered on Feb 13, 2018
2answers
Panasonic VIERA Flat Panel Televisions. Won't turn on. Made one popping sound. Now smoking.
I would say that's pretty much had it ,if there's smoke coming from the back something has burnt out I would take it to a TV specialist to see if it can be repaired Nick
2/3/2018 2:11:06 PM • Panasonic VIERA... • Answered on Feb 03, 2018
Panasonic Viera TC-P50S2 50" Plasma TV Logo
11 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
panasonic viera not working 10 blinking
  • Televison & Video
