20 Most Recent
Acer Power FG (APFGUP5161) PC Desktop Questions & Answers
Http://musclebuildingbuy.com/clx-male-enhancement/
The trial period is normally only for a number of weeks, therefore it is not really long enough to see massive benefits (most products need in order to taken for no less than 3 months for maximum results). However, this should be long enough for in order to establish how the product is beginning to be right for you.
Http://www.beaudermaskincare.com/dermaclear/
How To Get Soft Skin In Flat 2 Weeks
Actually, your actual age doesn't affair. We are all aging; we are aging all of the time. Should you be still in your 20s, you probably feel invincible against the slow creep of increasing older. Then you hit 30 and also in the mirror and see, gasp, lines inside the mouth, a touch of wrinkling, and a bit of of bagginess under up your eyes.
Computer has not power
If the power supply is bad replace it.
If the computer boots up for a second and then shuts down you can try the following method:
Remove the battery for a few minutes, put the battery back. Locate the connection to the power switch, turn computer on and then quickly disconnect the power switch
. If you have a battery with a power switch you can use that instead. Otherwise if this method solves your problem you will have to turn the computer on and off by plugging and unplugging it.
If you are going to get a new power supply, look for one that has a power switch on it.
I have an acer power
Well ,
Insert the windows disk , make sure the boot priority is set to CD/DVD ..boot the windows xp disk
and format the hard drive using NTFS full format.
Please reply for any furthur issues
Hi, I have problem with my ACER P4, when the power
maybe 2 reasons
- virus attack
- hardware failure
virus attack - best bet use rescue disk from nt virus company
like kaspersky rescue disk, bitdefender rescue disk n
etc
hardware failure - maybe cause by heat...check your coller system
like cpu fan
it's worth to try :)
Acer power fg does not start up for a long time.
Your heat sink is not properly working. this is because when cpu heat crosses threshold it shutdowns it self. it will not start again until it cools.
Try to remove the heat sink and then clean the base of heat sink which sits on cpu and apply the cpu thermal interface material. this is obtained in any computer accessories shop. shouldn't cost much. if available go for Cooler Master Cpu interface material.
