20 Most Recent Jamo DVR-50 System Questions & Answers
The impedance may be marked on the actual speakers inside the enclosures.
Jamo DVR-50... | Answered on Jul 04, 2017
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Jamo DVR-50... | Answered on Apr 27, 2017
You can replace DVD unit with one est?ndar for pc.
The only thing you must do is remove the front of the tray.
Jamo DVR-50... | Answered on Mar 03, 2015
Guess it would be cheaper to buy the DVR-60 , og DVR-70. I recall having seen good publicity on the dvr-60, but guess it would be hard to get your hands on that one. I have found the dvr-70 at the price of aprox. 200£. If you change the "motherboard", it will probebly brake down again, en just as expencive. I believe the cabinet is overheating do to lack of aircirculation, when you open it, there is no dust to be found at all...
Jamo DVR-50... | Answered on Aug 15, 2010
Might have got something to do with the powersuply, tjeck http://www.fixya.com/support/t3738600-receiver_doesnt_start . I am about to give it a go, I have a dvr 50, and my friend has got one aswell, and it is my belives the powersuply is creating all the noise, and your problem will probably only become worse.
to rectify this problem you will have to replace few capacitors in the power supply circuit. Caps to replace are C16, C17, C21, C26, C27, C32, C47. Be very careful with two screws located under the heat sink. DO NOT MIX THEM WITH THE REST OF THE SCREWS.
You have defective caps on the power supply pcb which needs replaced.the top of the caps will look like they have been bubbled up..change all of those that look like that.
Jamo DVR-50... | Answered on Apr 15, 2010
you have a defective power supply.there will be caps on power supply that will need to be changed,change the caps that looks like the tops are pushed out.unit should then work.
If cleaning the laser lens assy does not take care of the problem you will have a defective laser assy.
there will be bad caps on the power supply pcb assy,change those capactors that have been bubbled,tops pushed outward, and it should work.
Jamo DVR-50 System Logo
Popular Tags
33 questions posted
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jamo Audio Players & Recorders
Most Popular Question
receiver doesnt start
  • Audio Players & Recorders
