20 Most Recent
HP Pavilion 524w (DB280AR#ABA) PC Desktop Questions & Answers
How to reset
Which operating system ??..
HP Pavilion Recovery Partition
Accessing the recovery partition on your HP
Pavilion laptop allows you to restore your computer to speed it up, eliminate a
virus or repair your Windows operating system.
The Recovery Manager program makes it possible
to restore your laptop to its settings as of a previous date or restore your
computer to its original factory settings, which will erase all of your
installed programs and personal data.
Using the recovery partition allows you to
bypass the hassle of keeping track of recovery discs, which could be damaged in
storage, rendering them useless when you need them.
Turn on or restart your HP Pavilion laptop.
Press "F11" when the "Press
<F11> for recovery" message appears during the HP Pavilion boot
process.
Select "Recovery Manager" from your
list of recovery options and press "Enter."
The Recovery Manger program will open on your
screen, and you can begin the recovery process.
Access Recovery Manager Within Windows
Click the "Start" icon or "Start" button
in the lower left corner of your Windows home screen.
Click "All Programs" and then "Recovery
Manager."
Click "Recovery Manager" again to open the
Recovery Manager program on your HP Pavilion laptop.
using the hp recovery
manager in windows 7or
While restarting the computer keep
tapping on the F10 key
on the next screen you will find start system recovery , and on the next screen
you will find advanced options
in advanced option you will find an option for Destructive Recovery.. click
that
If you are not able to run the recovery on the computer as above then you will
need no use a set of recovery cds..... if you dont have them you can get it
from HP..
or
HP Desktop factory settings
The HP Recovery Partition that comes pre-installed on most
new HPs is like built-in insurance if your system becomes unstable or fails.
If the problem is severe enough, you may not be able to
start the HP Desktop Recovery Manager from Windows but you can start it
manually by following the steps below.
Disconnect all peripheral devices and power on the computer.
Press the F11 key after the computer first powers on to
start the HP Recovery Manager.
Follow the on-screen instructions to back up recoverable
files on the hard drive to an external drive or media.
Continue following the instructions to recover the hard
drive to its original factory condition.
Click "Finish" when the recovery is complete.
Reconnect devices and reboot the computer.
Reinstall software and update Windows and HP to current
settings.
Performing an HP System Recovery
(Windows Vista)
My computer is saying that the system is not fully
Which operating system ?????.....
settings.
(Windows Vista)
process.
Manager."
Putting wires back on motherboard
Which type of wire's are they? If you are talking about mobo onboard speaker and front led cables. It should be written on motherboard itself. You need to take it to bright light and try to find out. If it is speaker cables it should be in spkr word. If iti s front LED then it should be colour coding on motherboard. Good luck with that.
I have the hp pavilion
The compatibility isn't with the memory, it's with the motherboard and its chipset. In your case the motherboard is a FIC AM-37 which has an VIA KM266A chipset - an extremely old chipset . The only processors accepted are AMD Athlon XP of the first generation of which you already have the fastest version
http://en.wikipedia.org/wiki/AMD_Athlon(tm)_XP_3200%2B#Athlon_XP_.22Palomino.22_.28Model_6.2C_180_nm.29
So no, it's not possible to upgrade it. You will have to buy another motherboard-processor combo.
Hello there:
Hello Mike, Hi, may I suggest you try first to defrag your hard drive, Im sure when you power on your PC, the hard disk led keeps on blinking, your hard drive may have developed bad tracks and sectors, this slow moving process tends to go forever.
Defragmenting and checkdisk can find faults and bad sectors and tracks that slows down the performance of your PC.
Reformatting should be done if your defragmentation procedure fails to speed up your PC.
Try to run an antivirus program, which may help speed up your PC by detecting viruses, that tends to load forever, or slow down the booting process.
PThe computer turn off after
ok if the computer works for about 10 minutes then shuts down then i would say its not the hard drive but the cpu fan. when your cpu heats up it shuts down when it reaches a certain temperature to protect itself. open your case and check that the cpu fan is working if not check it is plugged in correctly by unplugging it then plugging it back in, somtimes the connections can become oxidised and loose contact. if your cpu fan is working then let me know and we will try something else. let me know how you go.
How to get motherboard out of a hp pavilion 524w
On the outside, disconnect the power-cable, then the keyboard/mouse/video/audio/USB/printer cables.
Disconnect all the cables from the power-supply to the devices (disk, CD-ROM) and to the motherboard.
On the outside-back, remove the screws holding the power-supply in position, and then remove the power-supply.
Remove the screw holding each add-in card (audio, video, modem).
Remove each of the add-in card(s).
Remove the ribbon-cables from the motherboard to the diskette & disk-drive & CD-ROM.
Look for screws holding the motherboard to the case.
Remove those screws, and gently lift out the motherboard.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
