20 Most Recent
HP Compaq d220M (829160054797) PC Desktop Questions & Answers
Sound
i need soundmax for my orange pc
I want to download audio
you can go www.driverguide.com. sign up for free account. the look for the driver AC97 integrated.
No consigo el controlador de ethernet para
Este es el controlador o el
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=337529&prodNameId=337531&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=ir-66362-1
Este es el controlador de
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=337529&prodNameId=337531&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=PSG_I19128-102605
Is there anyway to get my internet to work without
Hi friend,
This is not posible becouse if you want to use in your ssytem,you need to install eithernet drivers becouse without LAN or eithernet drivers you not able to show or connect the LAN connection.
When you purchase a system ,you collect a motherboard cd ,eithernet or LAN drivers already present in that CD,if you have not a CD,go to cyber cafe and download the approperiate drives .
Thanks,
It wont turn on help please
Sounds like the power supply is out. Remove the side panel, look at the wattage and type of PS that it is, look on ebay and buy a new one. (they are much cheaper on ebay). You can always go to your local PC supply store, staples, best buy etc, but they are much more pricey.
Make sure you get the same or slightly higher wattage your pc requires. NOTE: the power supply is the chunk block on the back of the computer that the power cord plugs into. It is very easy to remove and replace. Just make sure you ground yourself before reaching into the computer casing. IE> keeping feet still, touching the metal casing of the pc BEFORE reaching in and touching any components inside the computer.
Note wiring disconnected and appropriate places replacement PS that needs to be replugged.
My pc doesn't boot up window i have a hp and xp it
try this:
Turn Off the computer
Turn it on, then press F2 to go to the BIOS. (while your pc boots the black screen)
Then, look for the Advanced Menu, where it will display your drives.
Do a hard disk test, to see for any hard drive errors.
If there is any, that is a sign that you must replace your hard drive.
Hopes this helps! ^_^
Compaq d220m
You just need to purchase a standard PCI ethernet card. They run about $20 for a wired card. Wireless cards for desktops run closer to $50.
Here's an example from Newegg.com:
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=27&name=Network-Interface-Cards
In general, online retailers show these cards under "Networking"
Hope this helps!
Need windows 2000 server nic driver
Hello sir,
Try this link for Windows 2000 server.
http://www.opendrivers.com/driver/212753/3com-etherlink-server-nic-3c985-3c985b-driver-
windows-2000-free-download.html
Best of Luck
Don't forget to rate the solution.
thanks
