20 Most Recent HP Compaq d530 SFF PC Desktop Questions & Answers
2answers
HP compaq d530s SFF pci slot1 not worknig
Hi , with the computer powered off and ac power plug removed, press down on power button to discharge any residual energy noting any mainboard mounted LED lights have stopped glowing, then try reseating the " horizontal mounting bracket" ( remove the attached expansion card device ) restart computer , then shut down again , install the expansion card device and restart - hopefully now the pci bus will connect and the card detected and reinstalled by Windows
3/5/2018 12:52:38 PM • HP Compaq d530... • Answered on Mar 05, 2018
Hp compaq pd1068p driver download
so , you meant ? "where can I" ? as in a real question? Abdellatif Ziati wants answers to this question , hyJacking 2013 posts to the wrong forum D530?? NO OS stated, and drivers match, OS, windows what. and what fails, what feature fails,, the PC D530 is obsolete and HP has no support now for it. so google all day long and find it, and get the PC infected. ive no idea what pd1069p is.... nor does HP searches find it. the D530 is 14 year old now. an old Pentium 4 box. some came with windows 2000, (17 year old OS) here is the old data sheet on this Relic PC. http://www.hp.com/ecomcat/hpcatalog/specs/emeapsg/99/D530SERIES.pdf we take these to the dumps, and give it the last rights. RIP
12/13/2017 12:04:40 PM • HP Compaq d530... • Answered on Dec 13, 2017
2answers
I have a HP D530 SFF PD174UC motherboard that I
go to the web page for the mother board and download the audio driver for it or go to the web page for the sound blaster card and down load the driver for it from there
11/12/2017 12:05:18 AM • HP Compaq d530... • Answered on Nov 12, 2017
Audio drivers Hp Compaq D530 SFF running on Windows 7 ultimate version
what is your question please?
10/26/2016 5:04:28 PM • HP Compaq d530... • Answered on Oct 26, 2016
Full Restore of Window XP of HP Compaq D530
u need to use system recovery cd supplied with system. if u dont have, create the same from your computer from recovery partition.
9/2/2016 6:52:01 PM • HP Compaq d530... • Answered on Sep 02, 2016
Does my hp compaq d530
The HP Compaq Business Desktop d530 Series Small Form Factor supports 1 Low Profile 8x AGP Card. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
4/28/2016 4:52:32 AM • HP Compaq d530... • Answered on Apr 28, 2016
How do remove smart card Authentication errors in my hp compaq?
Try this Press F10 and change the security settings to remove the need for the smart card to login. This will eliminate the authentication errors associated with the faulty card. See this web page on how to do it. HP Compaq dc5700 Business PC Computer Setup F10 Utility
2/24/2015 9:34:16 PM • HP Compaq d530... • Answered on Feb 24, 2015
How do i repair green blinking light in motherboard and not powering up?
Is the CPU fan running ? Check power plug to cpu fan could be a spot on motherboard that has to be plugged into with power.
2/13/2015 3:32:49 AM • HP Compaq d530... • Answered on Feb 13, 2015
2answers
Why would you want to try to repair a working green LED? But you need a manual, to check what the blinking light means. See how it flashes, because the board is trying to tell you what is wrong with these flashes. Like perhaps bad voltage, or bad RAM or ROM? or lost all settings.
2/12/2015 1:58:03 PM • HP Compaq d530... • Answered on Feb 12, 2015
Hp pro 3400 frontpanel pinout
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/manualsResults?sp4ts.oid=5160137&ac.admitted=1418921816948.876444892.199480143 http://h20566.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=5160137&docId=emr_na-c03550750&docLocale=en_US http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03550748-1.pdf Finally I would add that in these manuals, which my not contain the info you want (I should download or save the pdfs to your computer anyway), HP have lumped together q few models and even more motherboards so to me it's not clear which HP part number belongs to your PC. I would that (be careful here) mant motherboards have the same connector header pin-outs, but HP don't tell you what they - only a third party would do this. 18.December.014
12/18/2014 5:27:02 PM • HP Compaq d530... • Answered on Dec 18, 2014
2answers
920-fan command 2 pin connector from power supply
Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
11/20/2014 4:12:33 AM • HP Compaq d530... • Answered on Nov 20, 2014
0answers
0answers
How to chang ram chip
watch youtube
3/6/2014 6:59:54 PM • HP Compaq d530... • Answered on Mar 06, 2014
0answers
Bios update for win 8
refer to HP support website, type your model. available bios updates are ready for download in there.
2/11/2014 9:20:56 AM • HP Compaq d530... • Answered on Feb 11, 2014
0answers
HP Compaq d530 SFF PC Desktop Logo
412 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
920 fan command 2 pin connector from
  • Computers & Internet
