20 Most Recent
Motorola Mobility Universal Bluetooth Speaker Car Kit (HF820) Headset Questions & Answers
My sound is clear but caller on other end hears a echo of his own voice. HELP?
Its like calling into a radio station going on the air, and having your radio turned up while on the air you will always get an echo. Or at least a delay that other people will hear on their radio. it's the same way, with using a Car Bluetooth because they are hearing their voice coming through the speakers and going back into the microphone and then they hear that and there is your Echo. Unfortunately there is really nothing you can do except for ask them to deal with it :-(
5/1/2017 7:31:30 PM •
Motorola...
Answered
on May 01, 2017
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
