20 Most Recent Motorola Mobility HT820 Wireless / Cable Headset Questions & Answers
have you tried resetting the headset? or put it in pair mode?
Motorola... | Answered on Apr 29, 2013
I have turned my worn-out Motorola HT820 ear pads inside out and have cut off the excess parts of the edges. This worked just fine for me. Obviously the ear pads are not as soft as they used to be, though there're not as thick as well.
Motorola... | Answered on Sep 10, 2012
Most likely, the battery is dead, not holding charge. Have not beeb able to find info for a replacement battery.
Motorola... | Answered on Apr 07, 2011
Make sure your headphones are turned off. Hold call button for 6 seconds, until you see the light steadily lit. Now pair with your phone: Motorola HT820, and type passkey: 0000. Done!
Motorola... | Answered on Feb 11, 2011
El código de este auricular es '0000' (cuatro ceros). Si le falta la guia de uuario de su auricular, podrá descargala desde este sitio (solamente en inglés, inflelizmente). Un saludo,
Now in English, for other users out there: the passcode for this headset is '0000' (four zeros). By the way, if your headset's user guide happens to be missing, feel free to download it from this location. Regards, Carlos
Motorola... | Answered on Nov 19, 2010
Some delay might be normal, because your phone requires some time to encode the A2DP stream, and your stereo headsets will also add some more to the total delay time, since it has to decode that stream, but it all depends on the processor's hardware and power, the application being used to play the media file, the codecs used, the headset's quality, etc. So, in general, A2DP might not be the way to go, whenever image synchronization is required, like watching movies, music clips, TV streams, etc. Wired headsets would be a better choice for such cases, instead.
In can tell you that in my current phone,an Acer Tempo M900, if I run WMP to watch a MP4 encoded music clip, with its audio being streamed via A2DP to my SE HBH-IS800 stereo headsets, the sound delay might be considered negligible. I'm pretty sure newer phones would perform even better. But I remember having experienced heavy delays with other environments in the past.
Just my 2 cents... Carlos
Motorola... | Answered on May 28, 2010
0000
Motorola... | Answered on Jan 11, 2010
w760i pairs beautifully with a2dp devices with great reception. make sure your a2dp is in pairing mode.
Motorola... | Answered on Jul 07, 2009
Try bluesoleil software...
Motorola... | Answered on May 16, 2009
Same here. A real peice of trash!
Motorola... | Answered on Apr 09, 2009
I'm sorry, Verizon's only stereo bluetooth phones are the chocolate and the envy.
Motorola... | Answered on Mar 28, 2009
yeah... You need the 8120 pearl for that feature.. I am guessing you have an 8100?
Motorola... | Answered on Nov 30, 2008
Restart the PC, delete everything and pair again... that'll help!
Motorola... | Answered on Oct 14, 2008
What kind of driver u use for ur bluetooth? bluesoleil works ...
just push the button on the left for a while
Motorola Mobility HT820 Wireless / Cable Headset Logo
41 questions posted
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Radio Communications
Most Popular Question
motorola ht820
  • Radio Communications
