20 Most Recent HP Compaq Presario SR1810NX PC Desktop Questions & Answers
Sr181nx compaq presario won't boot up
why do this expensive first.? Its just a desktop, (and industry standard and easy to fix) why not a PSU first. vastly more cheap. i cant see that video card, it has name and model number and that matters big time if the card uses more that 75watts. (wrong PSU for the newer faster video card is doomed) you failed to say what the problem was before, the card. same,or just wanted faster video for say gaming. tell why the new card, history also matters and intents. lets do this the easy way. a list. the unstated monitor and number of it, never ever shows any text ever at any time. Blank to me means that, other say blank means windows dead. (totally opposite in facts) 1: so you push the PC cases power button, a: the PC is silent. ? (power cord connected, and any switch hear that cord entrance(1/0) is in the 1 position = on. b: the PC PSU fan runs now, it must or the PSU is dead. (answers are 99% the other 1% i handle in all cases(complex) we use a voltmeter to test power, in all cases. c: the PSU fan blows, (looking behind it in the PSU grill.) not packed in lint and stalled, or dead. d: the CPU fan blows, (slide lid off eyeballs on it) e: the CD tray ejects on command, if this all happens 12v and 5vdc are working, yes it takes more. in each case of testing above what fails , causes me to work that angle, that path, of power and logic inside. if the PSU fan never spins even for the magic 1 second rule. then the PSU is bad. the exception is if things inside the case are shorted. shorts cause all ATX class PSU made to shut down (stops a fire ) (some do this for any overload, overvoltage and any undervoltage condition, I call those PRIME PSU's (best) This is normal for short.(inside) to find shorts, we remove things from the inside if the case called stripping PC. down. first HDD (just power cable) next CD (same just powercable next the Video card, pulled, oops PSU now stay on, oops. next all ram pulled. PC may beep due to missing ram. but power goes one. and may stop but you saw power happen. last is the jumper test of a PSU. we unplug the PSU. 24 pin connector. then jumper as see here. pin 16 to 17 pull the conn,. and psu end jump it. turn on PSU and it must run its fan full time. it will have all the voltages seen here. http://www.pcdied.com/power.html#Jumper
3/4/2018 1:36:47 PM • HP Compaq... • Answered on Mar 04, 2018
9.5 seems now to be downloaded, but won't auto-instal
SR1810NX DT NO OS STATED, XP? WHAT IS 9.5 , Im totally clue less, use a noun name. gooling is clueless too... on that. like a game ? or what is it.? those exe are probably full of virus, tell what you are doing, what is the JOB, or goal , is this an AOL only program? why not ask on a AOL forum. this. https://help.aol.com/ form they have forum no less http://www.topix.com/forum/com/aol why not ask them directly we are not AOL here. at all.
9/18/2017 3:02:37 PM • HP Compaq... • Answered on Sep 18, 2017
How do you get to the screw that is under this plastic cover to remove the optical drive
Here's a link on the HP web site with instructions http://support.hp.com/us-en/product/Compaq-Presario-SR1000-Desktop-PC-series/1841793/model/1841794/document/c00639864/
4/27/2016 4:03:39 AM • HP Compaq... • Answered on Apr 27, 2016
Why does my compaq presario SR1810NX turn off immediately after turning it on ?
Beep sounds indicate a hardware problem, check you RAMs, remove them and air blow the RAM + its trays on the motherboard then try to boot up again.
2/20/2012 10:04:22 AM • HP Compaq... • Answered on Feb 20, 2012
HP SR1810nx wont load .NET evem afteer a XP reinstall
Can you provide a little more detail. Are you talking about the computer not loading windows, or something on a web page? Please be as specific as you can so I can help you with this problem.
3/8/2010 4:11:00 PM • HP Compaq... • Answered on Mar 08, 2010
Won't boot, says insert disk & press enter.
this means that the operating system is missing
and you will need to reinstall windows
try to borrow a disk and reinstall windows
hope this help
9/19/2009 5:07:27 PM • HP Compaq... • Answered on Sep 19, 2009
I want to add memory to My SR1810NX ... I need to
A movie is better than trying to write it here.
Check this out on YouTube.
http://www.youtube.com/watch?v=pwbA4f1O93s
7/20/2009 1:49:03 AM • HP Compaq... • Answered on Jul 20, 2009
My compaq sr181nx diplay monitor is now blurry
This could be a faulty monitor. Trying plugging in a different monitor to the computer.. If you continue to have the same problem with the second monitor, then it is your video card or on board video that is going out. If the video is fine after you tried the second monitor, then you need to get a different monitor for your system.
6/14/2009 5:27:31 AM • HP Compaq... • Answered on Jun 14, 2009
Task manager problems
get a start up manager program to stop the processes you dont need that will make it not run so much at start up and your computer will run faster and if you try to end one of the processes that the operating system needs it will tell you and not let you do it so just mess around with it and see what you dont need then you can stop it at startup from running
5/30/2009 6:20:18 PM • HP Compaq... • Answered on May 30, 2009
2answers
Recovery discs aren't working on my hp cq60-615dx, what should I try next?
Appears that recovery disk #2 is bogus. U can try to get a new set from HP (fat chance!) or you can do a reload from a normal, retail OS disk.
6/21/2017 5:57:29 PM • HP Presario... • Answered on Jun 21, 2017
Compac presario CQ62
Hello Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine. usually F11 or F10. others has DVD, check and see what you have of these two. in the first one, you recover from a disk partition the whole OS.
1/26/2017 6:41:46 PM • HP Presario... • Answered on Jan 26, 2017
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too! but be aware you have to be more specific on model, and BIOS dates.
1/26/2017 5:26:29 PM • HP Presario... • Answered on Jan 26, 2017
2answers
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
7/30/2014 9:40:23 PM • HP Presario... • Answered on Jul 30, 2014
Macerator is not working
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply" If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
5/13/2014 3:47:40 PM • HP Presario... • Answered on May 13, 2014
0answers
0answers
Hp 6830s
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air. You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
3/4/2014 7:59:33 PM • HP Presario... • Answered on Mar 04, 2014
Presario SR5050NX wireless upgrade
Ask The People Who Work At HP To Find Out !
2/18/2014 5:02:42 AM • HP Presario... • Answered on Feb 18, 2014
Dear sir am not getting clear audio sound from my
if u r listening extra vibration sound with actual sound just change speakers
10/28/2013 2:28:06 PM • HP Presario... • Answered on Oct 28, 2013
Computers & Internet Logo
10 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
compaq presario sr1810nx turn off
  • Computers & Internet
