20 Most Recent
Motorola Mobility MD700 Cordless Expansion Handset Questions & Answers
New batteries not holding charge
The problem is probably the AC adapter. If you have a voltmeter you can see what voltage is on the adapter output plug going to the base unit. Unplug the small plug from the base unit and measure. Since the batteries are 3.6 v, the power adapter plug needs to be something greater. Maybe 4.5 v. It should say on the AC adapter what it puts out (volts and max current). Usually the center is negative and the outside barrel of the plug is positive. Put the volt meter to 5v DC and put the black lead in the plug center and the red lead to the outside barrel of the small plug. If you measure a negative voltage, switch the leads. Make sure the Volt meter is not in current mode or you will be shorting the adapter at its output plug. If you get a reading larger the 4 volts then the problem is probably inside the base. There should be some circuitry to minimize charging current to the battery,.
2/16/2018 3:43:43 PM •
Motorola...
Answered
on Feb 16, 2018
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit
http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM •
Lands Phones
Answered
on Mar 21, 2024
SONIM XP 3800 VOICEMAIL INDICATOR STAYS ON BUT,NO MESSAGES=?
TRIED POWERING OFF-PROBLEM STARTED 2/WEEKS AGO.
1. First, try resetting your phone by powering it off completely and then turning it back on after a few seconds. This can sometimes resolve minor software glitches.
2. If the problem persists, you can try contacting your mobile service provider and ask them to reset your voicemail on their end. They might be able to resolve the issue from their system.
3. Another option is to manually check your voicemail and listen to any existing messages. Sometimes, even if you've listened to a message, the indicator might stay on. By checking your voicemail and ensuring there are no unread messages, it might help clear the indicator.
If none of these steps work, it could be a more complex issue that might require technical support from Sonim or your mobile service provider. They should be able to provide further assistance. Let me know if there's anything else I can help with!
2/5/2024 4:27:32 AM •
Lands Phones
Answered
on Feb 05, 2024
