20 Most Recent
GE 21008GE2 Dual-Handset Cordless Telephone Questions & Answers
No dial tone on my handset
when the phone rings just pick up the hand set and answer
if that doesn't work press the talk/answer button and answer
GE 21008GE2 2.4GHz Dual-Handset Cordless
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/21008_DOM_ES_CL_IB.pdf
The 21008GE2 is a phone, not an answering machine. It doesn't store messages that can be accessed from the phone or another phone.
If you want to access messages on an answering machine, you'll have to tell us the make and model of the answering machine.
When i answer the other person can hear me but i
Hi Friend,
The other Person's speach you can't hear ,the problem is due to the mike in your phone,for example check it by switching on the Loudspeaker u will be able to hear.So kindly change the Mike in your mobile so you can resolve this problem
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Second phone not working.
From the manual:
VERY IMPORTANT: BOTH HANDSETS MUST BE REGISTERED TO THE
MAIN BASE BEFORE USE. After the 2nd handset has charged for 16
hours, place it on the main base station for 20 seconds, it will then
automatically register and verify its security code.
GE 21008GE2-A Dual-Handset cordless phone
Here's what seemed to work for me.
Hit the button that says ringer. then hit the number 1
then hit the button marked program (it is also the
mute button). Some combination of those moves
helped me go from Ringer OFF to Ringer ON.
Rocky on the River
Lost manual
GE branded Consumer Electronics are now sold by Thomson Consumer Electronics, Inc. Please call Thomson at 1-800-447-1700 for electronics product support.
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
