20 Most Recent
GE Cordless Phone 900 MHz Questions & Answers
How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Unable to dial out
This is wild, tomorrow's post today. Check the phone to see if it is in pluse or tone. Try changing that. Is this a cordless phone or a cell phone? If you changed a cordless phone batterie chech to make sure the new batterie plug is the same color as the old one. Some are black and some are white and the polarity is opposite.
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
