20 Most Recent Dell 1100 Laser Printer Questions & Answers
2answers
Problem with Dell 1110 printer - says it is online
you need to place the printer back online , to do this you need to go to the printer icon and right click , notice the option to USE PRINTER ONLINE select this option.
11/6/2019 6:40:52 AM • Dell 1100 Laser... • Answered on Nov 06, 2019
2answers
Where can i find the wps pin number for dell 1100 printer
Dear Press and hold few secs. blinks the light, it will print a report. the informations are there. Thanks.
11/6/2019 6:27:49 AM • Dell 1100 Laser... • Answered on Nov 06, 2019
Dell laser printer 1100 mac os x lion
If your Dell Printer is not working properly or you're facing technical problems setting up your printer and you want professional technician executive, this is when we step in. Dell Printer Customer Care Phone Number +1-833-260-7367 we have provided you the best dell customer support. when you facing any technical issues in dell printers. If you and your friends need and ask the best for dell printer services, you only need to https://easysupportnumber.blogspot.com/
11/4/2019 5:42:23 AM • Dell 1100 Laser... • Answered on Nov 04, 2019
Adjust top margin of doc?
Look in the preferences of your printer. Terry
3/3/2015 3:55:55 PM • Dell 1100 Laser... • Answered on Mar 03, 2015
How do you remove the pickup roller to replace the
Consult with the manual. Some models are easy to replace. If you take a good look at the pick up roller and watch how it comes off, just replace the same way.
6/6/2014 9:54:55 AM • Dell 1100 Laser... • Answered on Jun 06, 2014
0answers
Electrical conection
Yes the printer works off low DC voltage.
9/6/2012 8:45:54 PM • Dell 1100 Laser... • Answered on Sep 06, 2012
0answers
Prints multiple copies of job and will not shut
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
6/2/2011 2:37:14 PM • Dell 1100 Laser... • Answered on Jun 02, 2011
Does not go. Does
You may want to open it up and clean it out, (dust etc) it may having a thermo error thus shutting down to prevent any melting/overheating.
5/24/2011 9:34:32 PM • Dell 1100 Laser... • Answered on May 24, 2011
Can not print envelop with Dell 1110 Laser
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
restart the computer:
  1. Click Start and then Shut Down.
  2. Click Restart.
    The computer restarts.
11/2/2010 11:01:55 PM • Dell 1100 Laser... • Answered on Nov 02, 2010
Replace roller
10/10/2010 2:58:17 PM • Dell 1100 Laser... • Answered on Oct 10, 2010
My Dell 1100 printer is
With your printer, it's not possible to simply unlock and pull out the fuser unit, but to clear the paper jam inside or near the fuser unit, you have to access from the front.
Open the front access door, pull out the toner cartridge and the drum, then you'll be able to see-through the passage upto the Fuser unit. From there you can pull out any obstructions or broken paper stuck beside or inside the compartment. To remove your fuser, you'll need to remove the screws (there should be two screws,). But this is not included in the troubleshooting measures, you can still remove the jammed paper from the front access door. If you don't know how to disassemble the machine, I wouldn't recommend you do it yourself, rather call a friend or other guy who has a little disassembling laser printer and help you fix it. Please note that fuser unit is very hot and you can only access it after the printer is kept off for at least 30 minutes, if done without proper precaution, you may damage the fuser unit (I hope you understand the contraction and expansion of an object when heated and cooled).
Removing fuser in a Dell printer (all almost dell printers) requires at least 4 screws to be removed and it's also in two steps, one before you reach the unit i.e. removing the cover and next, after removing the cover. It's fitted inside the compartment which is not accessible like Hp or other laser printers.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
10/4/2010 7:46:55 PM • Dell 1100 Laser... • Answered on Oct 04, 2010
I am trying to insert
The cartridge has a handle that folds down. You can reach in and remove the old one by pulling it straight out while firmly grasping the handle. Then simply slide the old one back in to get a feel for it. The new cartridge should look very similar to the old one and goes in exactly the same way as the old one.
9/17/2010 10:03:49 AM • Dell 1100 Laser... • Answered on Sep 17, 2010
Paper feeder stops after in about 2 inches
Have you tried cleaning the feed rollers with rubbing alcohol or soapy water? Just make sure to dry the rollers before trying to use the printer again. If this doesn't remedy the problem, check the paper feed path for obstructions (previous misfeeds or jams). Hope this helps.
9/17/2010 9:55:31 AM • Dell 1100 Laser... • Answered on Sep 17, 2010
Paper jams regularly
Please go through this link you can resolve your paper jam issue.
Click Here
3/29/2010 2:17:06 PM • Dell 1100 Laser... • Answered on Mar 29, 2010
5answers
I am trying to replace
Please download the userguide of Dell 1100 from the link provided bellow which shows the roller replacement:
http://safemanuals.com/314159.php?k=11c1ad8a8f67aa58c4e8004ea87f3514&ID=347704&q=DELL%201100
Normally it’s a clip-on rollers, which have a small tab on the end of the roller. If you squeeze this tab, the roller will slide right off of the axle. You can then squeeze the tab on the replacement roller to put it on
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
3/13/2010 1:55:40 AM • Dell 1100 Laser... • Answered on Mar 13, 2010
Dell 1100 Laser Printer Logo
Popular Tags
48 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
dell 1100 printer
  • Office Equipment & Supplies
