20 Most Recent
Dell 1710 Laser Printer Questions & Answers
The paper jams half way through
I would remove the paper tray, inspect the area carefully and look for debris in the area, i.e. paper clip, staple, rolled up paper etc. Then do the same thing for the area where the paper exits. If you are able to turn the rollers by hand, the offending item may expose itself.
Having paper jams with my dell 1710 laser printer.
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
How do you get rid
check if the cylinder image shows stripes on it, if so then you have to remove the waste toner cleaning brush to clean the image drum.
and check the laser unit is clean, it is possible to remain deposited toner on it.
check image drum life may also be necessary to replace it.
