20 Most Recent GE 27851FE2 Phone Questions & Answers
manual
27851FE2 Phone Manual
GE 27851FE2 PhoneUploaded on Apr 06, 2014
Find the default access code lost the manual
The default security code is 123.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/27851_DOM_EN_CL_IB.pdf
8/18/2011 8:22:59 PM • GE 27851FE2... • Answered on Aug 18, 2011
I have put new batteries in my diverse 4016 phone
It looks that the handset is not charging from the base unit: if you have a multimeter you can check that you have a voltage slightly higher than your battery pack voltage on the base unit. Make sure the contacts are clean and If you have no reading, then the charger on the base unit is very likely defective.
If you do not have a multimeter, check and clean the (two) contacts on your handset and base unit to ensure proper electrical contact and that you see the charging indicator displayed on both the base and the handset.
If that does not work, to assess if the issue is with the handset, swap the phones from the base and the stand-alone charging station and repeat the test: if it works, swap the batteries between the handset to see if it makes any difference. If it works, then the issue might be with the original base unit handset as you have now 'tested' the new battery on the alternative handset. To summarize, it is a test by trial and error swapping.
Hope the information is of assistance.
9/26/2010 11:46:35 PM • GE 27851FE2... • Answered on Sep 26, 2010
Can't turn off the spanish
To change to "English," press and hold the skip button on the base unit for 2 seconds.
NOTE: In remote access mode, the system follows the selected language. The voice prompt language cannot be switched remotely.
Cheers!
2/14/2010 11:43:54 PM • GE 27851FE2... • Answered on Feb 14, 2010
4answers
I have a ge27851f-2 and
You can try:
1. Put the second headset in the main phone charging base (IE the base where the phone line is plugged in) for a while (at least 30 seconds) then you can go on to use it and charge it in its regular charging base.
2. If still doesn't work, remove the batteries from both phones. Then repeat step 1.
Good luck.
11/6/2009 8:15:58 PM • GE 27851FE2... • Answered on Nov 06, 2009
I have a ge27851f-2 cordless
If the base station is plugged into the phone line you should be able to designate one phone as the master. That phone should be on the base station when charging. If you look in the manual it should show you how to redo the master. It's usually just pushing a button when on the station. Just takes a second. That will also enable the phone to work with the base station. It locks out any phones that haven't been physically connected to the bases. To do the second phone you may have to do a slightly differant process to register it with the bases.
11/4/2009 5:08:42 AM • GE 27851FE2... • Answered on Nov 04, 2009
Both handsets say unavailable even
Please Re pair the phones with the base station. If you need instructions please post the brand and model of the phones / station.
11/4/2009 4:12:27 AM • GE 27851FE2... • Answered on Nov 04, 2009
How do i register anadditional phone
Should be a feature available through your menu feature on the new handset.
Check your owner manual or visit GE website for complete details on this model.
thanks for using fixya.com
a
10/26/2009 11:01:43 PM • GE 27851FE2... • Answered on Oct 26, 2009
I need help
try this page...:
http://images.owneriq.net/download/images/9/99351467-0ae8-2444-1dd3-486419692db0-000001.png
5/11/2009 2:07:24 AM • GE 27851FE2... • Answered on May 11, 2009
Answering machine does not work
this page may hold an answer:
3/20/2009 7:45:40 PM • GE 27851FE2... • Answered on Mar 20, 2009
I need the manual for 27851FE1-A
Here's a link to the downloadable manual on the GE website:
http://www.home-electronics.net/ge/pc/IB/27851FE1_IB.pdf
3/3/2009 4:56:30 AM • GE 27851FE2... • Answered on Mar 03, 2009
The user manual GE 27851 2.4 GHz phone
CLICK HERE for a PDF file of your user manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
2/16/2009 9:11:30 PM • GE 27851FE2... • Answered on Feb 16, 2009
Answering machine part of corded phone will not pick up
After researching this model it would seem that you have a bad one. Here's a link to the product reviews for your phone..
http://www.lakesidenetwork.com/electronics-014/ge_cordless_2_4_ghz_27851fe2_phone_with_dual_hand.html
Good luck. If this helps you plz rate this for me. Thank you kindly.
2/3/2009 12:31:54 AM • GE 27851FE2... • Answered on Feb 03, 2009
Spanish to English
what model of answering machine?...that i need to know!
1/28/2009 2:01:26 AM • GE 27851FE2... • Answered on Jan 28, 2009
2answers
User manual
A lot of GE models use 123 as the default code. Give that a try.
11/5/2008 5:45:11 PM • GE 27851FE2... • Answered on Nov 05, 2008
CID
try this page..:
6/2/2008 2:13:36 AM • GE 27851FE2... • Answered on Jun 02, 2008
I have lost the manual
heres a link to a site that has the manual for this phone:
http://www.retrevo.com/support/GE-27851FE1-Telephones-manual/id/512ag001/t/2/
6/2/2008 2:09:38 AM • GE 27851FE2... • Answered on Jun 02, 2008
Setting the number of rings
try this page...
6/2/2008 2:08:52 AM • GE 27851FE2... • Answered on Jun 02, 2008
GE 27851FE2 Phone Logo
Popular Tags
31 questions posted
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
GE Lands Phones
  • GE Lands Phones
Most Popular Question
put new batteries in diverse 4016 phone
  • Lands Phones
