20 Most Recent GE 28021EE2 Phone Questions & Answers
Phones won't charge
yes batteries can loose charging capabilities
11/2/2017 3:38:18 PM • GE 28021EE2... • Answered on Nov 02, 2017
Will not ring
Had the same trouble reset the phone to defaults and do not register handset. Enter the area code and program the ringer volume. Use the PROG (MUTE PROG) key & the CALLERID-VOLUME buttons to make selections in the menu on the screen. to save the setting press the PROG key.
6/9/2013 2:02:38 AM • GE 28021EE2... • Answered on Jun 09, 2013
What happen when the phone display screen shows
it means that you are to far away from the main signal. where the voice mail is. if you are not to far away try putting your phone on the main base and use it again hope i help
9/17/2011 7:44:14 PM • GE 28021EE2... • Answered on Sep 17, 2011
I think it needs a new battery, should I get one
Getting battery is much cheaper than getting a new phone.So please get new battery.
Thanx
7/21/2010 10:36:45 AM • GE 28021EE2... • Answered on Jul 21, 2010
GE 28021EE2 series GE phone
You can find the manual in .pdf format at:
http://www.retrevo.com/support/GE-28021EE2-Telephones-manual/id/511ci976/t/2/
Randy B.
6/20/2009 10:16:25 PM • GE 28021EE2... • Answered on Jun 20, 2009
2answers
Display says searching,wont stay charged for more than 20 min.
Did you find the fix? I have the same problem
3/27/2009 1:56:38 AM • GE 28021EE2... • Answered on Mar 27, 2009
GE phone answerer model 2-9876. Very much static on two incoming calls, 8 days apart. Only times in 26 years.
That will be because the static was at the callers line, not at your end. At this time of year it is water in junction boxes at the caller's residence. If it was on every call, it would be down to your connections.
5/4/2023 11:52:35 PM • GE Lands Phones • Answered on May 04, 2023
2answers
General Electric GE 27956FE1 Dect 6.0 Photo Phone with Photo CID. It has a white screen?
Question edited for a lot more clarity. You are only the second person to have this issue. Refer to the manual and do a reset, but in doing so you will lose all saved data. https://www.google.com/search?q=general+electric+ge+27956fe1+white+screen+fix ..
4/16/2023 8:00:41 AM • GE Lands Phones • Answered on Apr 16, 2023
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
1/27/2023 7:06:13 PM • GE Lands Phones • Answered on Jan 27, 2023
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
11/25/2022 12:51:11 PM • GE Lands Phones • Answered on Nov 25, 2022
2answers
GE 2-9831a - My landline phone can't get a dial tone?
Line in use means another phone is being used. If you have more than one phone, the second phone is off the hook or someone is already using the phone. Check all phones and be sure they are hung up.
8/29/2022 3:20:12 AM • GE Lands Phones • Answered on Aug 29, 2022
Fred, thanks, but where is the third wire on my GE speakerphone desk phone.
Posting a follow-up as a new post doesn't work here at Fixya because posts are not threaded by poster or previous posts. Therefore this post has no context to your previous post. Also worth noting that it was 15 days ago!If you click COMMENT under Fred's answer, he will get a notification and come back to help you. Thanks Karenhttps://www.fixya.com/support/t29866451-ge_speaker_phone_29480ge2_when_someone..
3/30/2022 4:33:07 PM • GE Lands Phones • Answered on Mar 30, 2022
GE 2-9451 4line pro How do you activate called ID?
only the service provider can activate that and it costs more money
9/24/2021 12:55:27 PM • GE Lands Phones • Answered on Sep 24, 2021
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work. I hope this helps. Cindy Wells
6/3/2021 9:56:07 PM • GE Lands Phones • Answered on Jun 03, 2021
I already asked this question forty minutes ago. how to reset my security code on my GE digital messaging system29871GE3-A I can't retrieve any messages.
Probably you wont be able to change password without erasing all messages. That is the point of having security code
4/25/2020 11:53:23 PM • GE Lands Phones • Answered on Apr 25, 2020
Owner manual GE 35027 recorder where to find pdf owner manual download
https://www.geappliances.com/ge/service-and-support/literature.htm
1/30/2020 10:43:23 AM • GE Lands Phones • Answered on Jan 30, 2020
GE 28021EE2 Phone Logo
15 questions posted
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
GE Lands Phones
  • GE Lands Phones
Most Popular Question
phones charge
  • Lands Phones
