20 Most Recent Nikon Monarch ATB 7345 Binocular Questions & Answers
How to tighten binocular hinge
Simple solution: Pry or unscrew the cap covering the end of hinge shaft on the rear of the binocs (between the eyepieces). Use a screwdriver that fits snugly in the slot on the end of the shaft & tighten to desired tension. Place a dab of Goop-type cement on the inside of the cap if it was pried off & press it firmly back on the shaft . Helpful hint: Slide a small knife blade (an old dull one you don't use for cutting) under the cap and gently work your way around to pry it off. Note the position of the index numbers before you remove it so you can replace it in the same position.
7/13/2013 4:54:40 PM • Nikon Monarch... • Answered on Jul 13, 2013
The eye relief is broken. I need to replace them.
You can contact Nikon at 800-645-6687
Thomas E. Kuenzli
Eagle Optics
2120 W. Greenview Dr.
Middleton, WI 53562
(800) 289-1132
1/7/2011 5:10:37 PM • Nikon Monarch... • Answered on Jan 07, 2011
Cannot focus single focus side
First you must focus the left eye on a given object with the center focus wheel. Once the left eye is sharp while looking at the same object adjust the right eye to be as sharp as possible. The right eye diopter is only meant to adjust for the small differences between the eyes.
Thomas E. Kuenzli Eagle Optics (800) 289-1132
12/23/2010 7:12:48 PM • Nikon Monarch... • Answered on Dec 23, 2010
I have a pair of Monarch 10 x 42 binoculars with a
Send them back to Nikon. The first pair i had did it twice, then they sent me a brand new pair. Here a year later with new pair the eyecup pieces that turn in and out already have cracks in them again.
8/22/2010 2:36:48 AM • Nikon Monarch... • Answered on Aug 22, 2010
Nikon Monarch 10 x 42
if the warranty has expired you can't get any replacement
you have to buy a new one
if not talk to the shopkeeper or write a letter to the company
2/12/2009 8:09:10 AM • Nikon Monarch... • Answered on Feb 12, 2009
I bought a pair of 10x42 Nikon binoculars about three weeks ago and am seeing double. How can I fix this?
Adjust the the width or the eyepieces as you are looking through them until you see a perfect circle. Sorry for the 5 year delay. Your post attracted spam which was removed and that action put it back to the top of the list. I had answered before I noticed :>D
6/10/2022 9:10:25 PM • Nikon Optics • Answered on Jun 10, 2022
How do I remove water from INSIDE my Nikon A211
Get some industrial size silica gel bags and warm them in the oven. Put a couple of bags inside a large Ziploc bag with the binoculars and leave them in a warm place like an airing cupboard for a week. It there is a lot of water, remove the object lenses (the large end, they should unscrew) and shake the water out. The gel packs last forever and can be dried out in the oven before use. I have some from the mid 1960s as my dad used got them at work from rolls of copper foil that were delivered to make printed circuit board. https://www.amazon.com/large-silica-gel-packets/s?k=large+silica+gel+packets ..
6/10/2022 9:02:12 PM • Nikon Optics • Answered on Jun 10, 2022
I was traveling with the
depends on what they cost. you did not list model or maker.sounds like they can be repaired , lenses have shifted, and has to be realigned. can i help further [email protected]
3/27/2020 9:48:14 AM • Nikon Optics • Answered on Mar 27, 2020
Nikon binoculars ser#AD 002995 10x42. 5.4 degrees need parts?
No thanks, but thank you for thinking of us
7/18/2019 8:58:22 PM • Nikon Optics • Answered on Jul 18, 2019
The I have a Nikon Laser 800 Buckmasters 8 x 28 4.5 " The black exterior surface is dissolving and is all sticky. Is there a cure for the problem?
This YouTube video shows how to clean the lens.
https://youtu.be/p_KImwAxvwk
6/5/2019 9:47:57 PM • Nikon Optics • Answered on Jun 05, 2019
I need a replacement battery cap for my Nikon Rifle Hunter 550, how can I order one
notify nikon or a camera / electronics repair shop online search
12/2/2018 3:52:31 PM • Nikon Optics • Answered on Dec 02, 2018
Is the Nikon Prostaff 3 Rangefinder good for the golfer?
Nikon Prostaff 3 Laser Rangefinder You would obviously expect something superior from Nikon. Well, this renowned company will not disappoint you. They have maintained their expert quality, but that does not make the product expensive. Nikon Laser Rangefinder gives you a crystal-clear image at a very low price. With the launch of Nikon Prostaff 3, two categories of rangefinder seekers have got something to rely on for their ranging needs. Golf players belong to one category while others who want to get top features but maintain a budget belong to another category. Many hobbyists and professionals are getting keen on using rangefinders. It enables hunters and golfers to have a smooth field of view. It gives you enough range and brightness for clear sight. Nikon Prostaff 3 Laser Rangefinder has created some buzz among outdoor lovers. The multicolored display is adequately bright and able to show distances in meters and yards. There is a continuous measurement mode that facilitates multiple measurements without requiring users to make any additional adjustments each time they switch targets. This mode helps users to gauge the accurate distance between particular objects and their current positions. The built-in slope compensation deals with the changes in slope heights almost accurately. Making precise measurements at different angles up to 89 degrees becomes a breeze.
3/17/2018 7:35:25 AM • Nikon Optics • Answered on Mar 17, 2018
What size lens caps for nikon monarch atb 10x42 binoculars
Why not measure the item and find out ?
1/18/2018 6:55:08 PM • Nikon Optics • Answered on Jan 18, 2018
2answers
Hi, tech help with a pair of Nikon binoculars that I have had for sometime now.
We might be able to offer advice if you were to tell us what the actual problem is.
1/10/2018 9:44:00 AM • Nikon Optics • Answered on Jan 10, 2018
I have a pair of
Sounds like internal fungus in the balsam. If it does not affect their use, I should ignore it.
8/20/2017 11:31:50 PM • Nikon Optics • Answered on Aug 20, 2017
Did you have binocular nikon monarch 7 8x42 and how much it cost
They are £399 at Wex Photographic (opposite Asda)
12/7/2016 9:11:56 PM • Nikon Optics • Answered on Dec 07, 2016
Nikon Monarch ATB 7345 Binocular Logo
21 questions posted
Top Nikon Optics Experts
john h
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Nikon Optic Expert? Answer questions, earn points and help others
View Most Popular
Nikon Optics
  • Nikon Optics
Most Popular Question
  • Optics
