20 Most Recent Xact Communication 22 CHANNEL FRS/GMRS 2-Way Radio Questions & Answers
First make sure it is charged then press and hold the power swich for about 2~3 seconds do not let go right away as the first of power up will put you in the time set /program mode.
Hutch
Xact... | Answered on Feb 27, 2011
You will need to run a wake up charge into the battery. The best way to do this is with a 6v lantern battery with 2 wire leads just put + to + and - to - by tickling the contact plates on the battery (do not hold the wires on for more than 3~5 seconds. two times should do the trick ,then put the battery back in and right back on the xact charger plug and it should start to accept the charge.I just did 4 of them that were out of use for 5 years and all came right back to life.
Hutch
try going to this site http://phone.manualsonline.com/manuals/device/twoway_radio.html
Xact... | Answered on May 25, 2009
Do a search on eBAY. There are lots of second source batteries there and they seem to be decent quality. I have bought many for all sorts of devices from these venders.
Xact... | Answered on Feb 03, 2015
your device should be marked with polarity and voltage requirements. Any power supply with the correct plug meeting those specs (if amperage isn't marked, look for one that is between 500- 1000 mA) should be fine. MAKE SURE it is a DC supply if the device you are using is marked DC.
Xact... | Answered on Oct 23, 2013
Run the Baofeng software that came with the program cable then download the Chirp software. If it does not show complete it will still work and update normally when restarted. Mine did the same thing and works fine
Radio... | Answered 7 hours ago
It is a direct entry scanner so just enter manual and program then enter the frequencies you want. Press enter after each channel and press program again to advance to the next channel and repeat.
Here's the Manual, check for a blown fuse:
https://www.manualslib.com/manual/946175/Sylvania-Skcr2613b.html
Radio... | Answered 2 days ago
I have a Schwinn 270 recumbent exercise bike. I was able to Bluetooth pair it to an Android phone using code 000000, but it was a useless pairing without the Schwinn app or an exercise app, and it did not offer an audio link.
Radio... | Answered on Apr 17, 2019
Xact Communication 22 CHANNEL FRS/GMRS 2-Way Radio Logo
8 questions posted
Top Xact Communication Radio Communications Experts
eradiostore
eradiostore
ka4iup
ka4iup
phgentry
phgentry
Level 1 Expert
Are you a Xact Communication Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Xact Communication Radio Communications
Most Popular Question
cannot charge battery xact model x2x
  • Radio Communications
