20 Most Recent
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Questions & Answers
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
Instructions
Google this. Instructions usually available on line. Or communicate directly with the manufacturer.
Light stays red after being plugged in for 24 hours
I am assuming that you are speaking of the charger. The Red LED shows that the charger is plugged into the wall. It does not show the charge status of the radio. These are very simple units, and it is not a "smart" charger.
How to get rx off screen
This model has a "Monitor Mode" feature that allows you to listen for weak signals on the current channel at the press of a key.
1.) To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
2.) To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
