20 Most Recent
HP LaserJet 1018 Printer Questions & Answers
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Printer offline
Brother printers are cost-effective printers that give up to mark printing. In addition to printing, a user can copy and scan from the printer works into a USB and also a wireless connection.
In Brother printers, offline failure happens once in a while. This writeup tells about the reasons for this error along with their solutions. We have read 'how to fix why is Brother printer offline issue' for both Windows and Mac operating systems.
Reasons that cause this irritating Brother Printer Offline Windows 10:-
1.Paper jam error.
2.Ink toner blockage.
3.Error in the network connection between your computer and printer.
4.Wicked or outdated printer drivers.
5. If the printers ' use offline mode' is selected, it may also show the offline error.
6.Wrong printer settings.
Just follow the steps which are mention on the blog to fix the
Brother Printer Offline Windows 10. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
SPOOLER PROBLEM FOR WINDOWS 7
dear user
for you to open the print spooler in windows 7.
right click my computer/select manage/select services and applications/select services/scroll down and look for print spooler/stop and start to refreshed it.
thanks
Device is connected waiting for
There might be some issues either with the printer cable or the USB port on your system... Just try another cable if you have one... or u can also try another usb port on the system...
How do l download hp laser jet 1018 to mac book air.
The 1018 is not supported by HP with the Mac OS Mountain Lion. I found this on an HP forum and it worked for someone else. You could try this:
Thank you for posting,
Unfortunately, HP laserjet 1018 is not suported in Mac OS X 10.8 Mountain Lion. How evere you can use the builtin drivers that goes along with the operating system and select teh driver of another printer and check.
Connect the printer to the computer and then go to System Preferences and click on Print and Fax. In the Print Fax window, lick on the Plus sign and you will find the printer, please select the printer and then under print using click on the drop down and click on "Select print Software" and in the list, please select HP Laserjet 1015 pr HP Laserjet 1022 and check.
If you don't find these printers in the list, please download and install the latest print driver version 2.12 from the apple web site using the link below.
http://support.apple.com/kb/DL907
After downloading and install the update, please try the steps given above.
Why is my printer making really loud grinding noise and will not feed paper or print
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Why left side light printing
This means the toner cartridge is getting low on that side. Remove the cartridge and shake it side to side to redistribute the toner and retry. You'll need a new toner cartridge soon.
How to stop printing
1. Turn off the printer.
2. Unplug the data cable going into the printer.
3. Remove the offending print job from the computer.
4. Remove any jammed paper as a result of Step 1.
5. Turn the printer back on.
Prints out of margin
what are the margins for the document. Most printers will print documents at a margin of 1 inch on all sides
