20 Most Recent
Jura Capresso H2O Plus 259 Cordless Electric Kettle Questions & Answers
My kettle heats water to
I think your kettle is having a switch problem. The switch is failing that is why it turns off and on by itself.
Also, there might be some sort of partial contact in the kettle which is causing it to connect and disconnect at interval. Heat from the kettle can cause wire(s) to melt....
You will have to get a Philip screw driver, open the part of the kettle where the power wire enters with the screw driver and make sure all wires are firm/intact....
Good luck.
My teakettle is about three months old. I was
Hi Nancy. There is a fuse or fuse like device in the bottom of your teakettle. There is also a temperature control switch which may be faulty. (if faulty, it is 'open' and the pot thinks the water is hot already) If you have a volt/ohm meter, you can probably find and replace it. You will need the replacement part and tools to install it, including pliers, screw driver and a crimp tool.
since it is three months old, you should consider contacting the manufacturer for relief on this matter.
Good luck on your repair and thanks for visiting FixYa.com today.
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
