20 Most Recent HP Officejet Pro K550dtn InkJet Printer Questions & Answers
Replaced HP 88 Printheads, still receive same
You either got a defective printhead or you are using generic inks, HP got real smart and added chemicals to their ink, if the printer doesn't see the right chemical makeup it will give that error and you need to flush the printhead and the pump and hoses with HP ink or the error will stay.
1/13/2010 8:00:38 PM • HP Officejet Pro... • Answered on Jan 13, 2010
Hp office jet k550 black cartage won't print color
You need to do all the maintenance and diagnostic cleaning using the printer software to align the print head and clean the nozzle....
6/15/2009 3:00:32 AM • HP Officejet Pro... • Answered on Jun 15, 2009
I have just replaced ink cartridges for HP Officejet 7000 E800 and the ink lights are just blinking on the printer. What do I need to do to resolve this problem?
After replacing the ink cartridge, the HP Printer light blinking that means your printer has some another technical issue. The HP printer blinking different type of lights. Let's discuss the reasons behind the HP printer lights blinking issue: When your HP Printer blinking orange light that means the problem with your printer ink cartridge, toner or may be corrupted configuration settings. If your HP Printer blinking Blue Light, it indicated the HP Printer isn't setup on the wireless network. Find the right solutions here and fix the HP Printer lights blinking issue.
10/12/2022 4:36:19 AM • HP OfficeJet... • Answered on Oct 12, 2022
2answers
How to reset printer hp offiject 6700
  • If the user cannot solve an issue that has been troubleshooting frequently, then obviously the last thing would do is to reset the printer.
  • To perform a reset, turn on the 123.hp.com/oj6700 printer by pressing the power button.
  • With the printer turned ON, disconnect the power cord from the rear end of the printer.
  • Remove the power cord from the wall outlet. Wait for a few seconds and re-connect the power plug back to the outlet.
  • Reconnect the power cord to the printer's rear. If the printer does not turn ON automatically, press the Power button. for More visit https://goo.gl/t55XMJ Call Our Toll-Free 1 888 224 4280
4/26/2022 11:29:52 AM • HP OfficeJet... • Answered on Apr 26, 2022
2answers
"Paper detected does not match paper size. or type selected. Make sure the paper size is correct to continue the job" This is now on the display window. Nno changes were made. Help!
You give no details what job has been sent to the printer before that. Probably your printer settings about the paper are some standard for your area like A4 for example, but you are trying to print a file, received from a place on earth, where the paper used in printers is different format and the file has been prepared for print on Legal, for example. To reset the process, find the print job in your Devices and Printers folder and delete it. Then power cycle the printer. Then check the document and make ajustments to it fitting the printer settings. Then print it again.
3/31/2022 5:01:24 PM • HP OfficeJet... • Answered on Mar 31, 2022
Why does exclamation point orange light flashing on HP Officejet 7110?
Hi, The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems. For more read... HP Support document and HP Tech Support . Thanks,
7/29/2021 11:51:54 AM • HP OfficeJet... • Answered on Jul 29, 2021
How do I reset an OfficeJet Pro X476 ? printer's admin functions are locked.
Found some things that you will have to check. Are you the IT Admin? http://data.manualslib.com/pdf2/48/4756/475532-hp/officejet_pro_x451.pdf?20be71eb5f9d0bcbf61131c493e0773d
  • These machines have a warning, that any problems beyond the basics you can generally fix, you NEED to call them.
7/29/2021 7:32:11 AM • HP OfficeJet... • Answered on Jul 29, 2021
3answers
Office jet pro 8710. will not print says the paper size detected 0 by the printer does not match the paper size selected (8.5x11in) for the print job
The Officejet 8710 printer can face paper mismatch issues if the paper settings are not set properly in the Print Preview box. Try setting the Paper Type option to Plain in the settings window that appears before performing the print. Change the settings to 8.5 x 11 in both the copier and the printer setting. There can also be an issue with the paper tray. Set the paper width guides correctly. Try printing a Configuration report to determine which paper size the printer is configured to. Any bits of paper stuck inside the printer roller might also cause paper feeding errors. Open the cartridge access door of your HP Officejet Pro printer. Wait for the ink cartridges to a position on the left. Look for any pieces of paper inside the cartridge area. If any bits are found, remove them. That should solve your problem. for more support Call our Toll-Free 1-866-293-9220 or visit https://goo.gl/Pkv63e
7/25/2021 10:35:59 AM • HP OfficeJet... • Answered on Jul 25, 2021
2answers
Hp Officejet 6000 not printing black ink, I have replaced ink cartridges, checked contacts, cleaned print heads, still not working
Try taking out the printhead and let it soak in "window cleaning" solution overnight or for about 8 hours. It should unclog the printhead nozzle. Put it in about half inch of the solution. It always worked for me. Make sure you wipe it dry un the back of the printhead when putting back into the printer.
7/25/2021 10:35:43 AM • HP OfficeJet... • Answered on Jul 25, 2021
I have been facing HP Printer error Code 49.4 c02 since last 1 month and its becoming very difficult for me to resolve this issue please help me to fix this HP Printer error Code 49.4 c02
This link might help: https://www.google.com/search?q=HP+Printer+error+Code+49.4+c02+manual&tbm=isch&ved=2ahUKEwj7no_OhqjvAhV3n0sFHWBkBxAQ2-cCegQIABAA&oq=HP+Printer+error+Code+49.4+c02+manual&gs_lcp=CgNpbWcQAzoECAAQGFCS4AhYiu4IYPD0CGgAcAB4AIABYogB5wWSAQE4mAEAoAEBqgELZ3dzLXdpei1pbWfAAQE&sclient=img&ei=ofNJYLvKIfe-rtoP4MidgAE&bih=625&biw=1366 or try to reach out to HP.
3/11/2021 9:22:46 AM • HP OfficeJet... • Answered on Mar 11, 2021
tip
How to Setup 123 HP OFFICEJET 3830 Printer
How to Setup 123 HP OFFICEJET 3830 PrinterUn pack the 123.hp.com/oj3830 printer from its packaging and keep the power cords ready to connect in its respective places. Now, place the cords firmly into the wall sockets so that there are no loose connections or any power issues with the devices. After connecting the cords, press the Home button on the left-hand corner of the printer.nice the basic setup is complete, install the printer software by visiting 123.hp.com or by inserting the CD which came with the printer. Follow the instructions on the screen to complete the printer installation process. Download the driver software from the website link 123.hp.com/oj3830 or 123.hp.com/setup 3830.
What are the steps to download HP Officejet Pro 8035 Driver?
See the plus sign beside software utility on this HP page? Click that and it shows the setup program for the printer which you must download. One such is for offline installation and that is how you would install it after downloading it to your download folder. YOu double click on the file there to get it to run AFTER you are offline, if you choose that option. I see there is a CRITICAL firmware update that needs downloading and installation as well. Do NOT attempt to install them simultaneously but rather sequentially. There is nothing wrong with them sitting in the same download folder prior to you getting offline for installation purposes. https://support.hp.com/us-en/drivers/selfservice/hp-officejet-pro-8030-all-in-one-printer-series/24208734/model/24208735
11/27/2020 7:24:03 AM • HP OfficeJet... • Answered on Nov 27, 2020
How do I get my Hp officejet 4622 to pull paper when printing?
Just clean paper pick up rollers. This video instructions show how to do it:
8/23/2019 4:39:35 AM • HP OfficeJet... • Answered on Aug 23, 2019
Does the 2nd paper tray from an HP Officejet Pro 8630 fit the new HP Officejet 8710?
Hello. No, it will not. Sorry.
8/21/2019 11:34:28 PM • HP OfficeJet... • Answered on Aug 21, 2019
I have a HP office jet 4652. It continues to print in the "Photo" setting even when I want to just make a copy from a document. It prints normally anything from my PC.
Ahhh. A fellow OfficeJet 4652 owner. I own one too. In your print driver, you want to click quality, and then normal.
5/31/2019 10:50:04 PM • HP OfficeJet... • Answered on May 31, 2019
Panasonic printer KX-MB1500 call service 17 error
Panasonic KX-MB 1111500 showing CALL SERVICE 17
2/21/2019 8:55:26 AM • HP OfficeJet... • Answered on Feb 21, 2019
How can I set upmy hp officejet v40 to scan? Please help
Here you can find the PDF manual, in there you have the installation instructions: HP Officejet V40 PDF Manual
10/7/2018 9:28:10 PM • HP OfficeJet... • Answered on Oct 07, 2018
Clean HP office jet pro 8600 plus
Unset, uplug.. reset all printer remove all history if you need trusted download page you could go HP Offce jet pro 8600 Install Guide and Driver Downloa HP Officejet pro 8600 Install Guide and Driver Download Oplost com
8/13/2018 10:26:29 PM • HP OfficeJet... • Answered on Aug 13, 2018
HP Officejet Pro K550dtn InkJet Printer Logo
5 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
replaced hp 88 printheads still receive
  • Office Equipment & Supplies
