20 Most Recent
Kyocera FS-C5100DN Color Laser Printer 23 ppm Questions & Answers
Kyocera FS-C5100DN shows Error message "close front cover"
what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
8/4/2017 12:59:46 AM •
Kyocera...
Answered
on Aug 04, 2017
Wont operate because display says 'close top cover' even though it is closed.
If you remove the toners you'll see a little lever usually has a yellow sticker attached that can be pushed forward or back make sure it's pushed towards the front of the machine then reload the toners and close
if it still won't close you may have broken the actuator off the lid that pushes the switch when the closes
3/16/2015 10:57:42 PM •
Kyocera...
Answered
on Mar 16, 2015
If you remove the toners you'll see a little lever usuall has a yellow sticker attached that can be pushed forward or back make sure it's pushed towards the back of the machine then reload the toners and close
3/16/2015 10:55:39 PM •
Kyocera...
Answered
on Mar 16, 2015
Why is the kyocera fs-c5100dn print smudging
If the final product is smudging after it prints out the fuser unit is not working and the toner is not fused to the paper. Also the paper should be warm when it prints out.
If it is during the printing you may have loose toner in the printer that is contaminating the print process.
8/29/2014 2:04:58 PM •
Kyocera...
Answered
on Aug 29, 2014
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
