20 Most Recent Motorola TalkAbout T5530 2-Way Radio Questions & Answers
FRS & GMRS frequencies have been preset by the governing bodies where these radios are licensed for use. They consist of Ch 1 - 14 for FRS or Family Radios Service (the new "CB" radio) and Ch 15 - 22 for GMRS or General Mobile radio Service. GMRS frequencies may be repeated 5 Mhz higher - the repeater input of channel 22 (462.750 Mhz) may be heard if close to the transmitter on Ch 22, but if a repeater has been set up to repeat signals in range on Ch 22, they would also be heard on 467.750 Mhz. The repeater will likely have one or more of the following: a high vantage point such as a hill or mountain top, may increased output power of up to 50 watts, or have an antenna with gain properties. Any one or combination of any of these benefits, will result in a significantly increased area of coverage.
FRS Frequencies Channel Frequency in MHz 1 462.5625 2 462.5875 3 462.6125 4 462.6375 5 462.6625 6 462.6875 7 462.7125 8 467.5625 9 467.5875 10 467.6125 11 467.6375 12 467.6625 13 467.6875 14 467.7125 15 462.550 16 462.575 17 462.600 18 462.625 19 462.650 20* 462.675* 21 462.700 22 462.725
It is important to note that only Ch 1 - 14 may be used without a license. Transmitting on any of the GMRS frequencies (Ch 15 - 22) shown in red in the chart above, requires an FCC license if used in the U.S.A. Other countries may or may not have laws for licensing the use of any or all these frequencies, so check before transmitting. Modifying an FRS / GMRS radio is a violation of FCC rules and if caught; can result in fines, prison or both.
If you'd like to be able to tune actual frequencies - and not be limited to specific channels, you ought to look into amateur ("ham") radio. While not in the FRS or GMRS bands, there are literally hundreds of thousands of frequencies to use once licensed. The ARRL (American Radio Relay League) has a great deal of info about ham radio.
I hope this helps & good luck! Please rate my reply - thanks!
Motorola... | Answered on Dec 04, 2017
It's very simple, you just need to get higher or where buildings do not obstruct the transmitted signal.
Some of these radios have transmitted 20 or 30 miles from a high spot to someone standing in the clear or when weather conditions increase the range.
Motorola... | Answered on Jan 31, 2015
You'll never see 8-mile range unless it's mountaintop to mountaintop. If there's any terrain/trees/houses it's just not going to make it...
That generally means that it's set to transmit on an invalid frequency.
Motorola... | Answered on May 04, 2014
Dear sir,
u can coonect the same via IP camera , u will have to open ip camera & find pre ampmlifier section for both inward & outward voice communication , then only it is possible or use Voice over IP routers , which has audio in & out port ,with some modification to walkie talkie handsfree
Motorola... | Answered on Jun 10, 2013
See previous Post...
Peter
Motorola... | Answered on Mar 10, 2013
Hi Ken,
Take your radio in to your nearest Radioshack or similar store, and they'll help you to get the Charging dock for your radio.
I hope this helps.
Cheers,
Peter
See previous entry,,,...
Peter
Motorola... | Answered on Mar 06, 2013
Yes it is a Motorola, no it is not made in Malaysia, USA or UK, but mass produced in China under license, and there my friend lies the problem.
From personal and from the many others who've posted on this forum re: Chinese made radios, they are ****, and a waste of money.
Very little info available, and what is available is written in CHINGLISH, which is a mongrel to understand.
Spend little, get little....
Spend more, get more...
That's what I did and still do on ebay, for a trusted brand from $150.00 upwards, you will be doing yourself a favour, stay clear of any radio equipment made in China, it's rubbish.
Cheers,
Peter
We have found this company http://www.wirelesspro.com/ for TalkAbout accessories.
Best regards.
Motorola... | Answered on Aug 07, 2012
Here's the manual - please review and feel free to ask any specific questions you may have.
Motorola... | Answered on Jun 21, 2012
  • Motorola two way radios were pretty standard across the board with their accessories and chargers. If it worked in one it was pretty much guaranteed to work in a different model one. This link here http://www.ewingenter.com/accessories.htm is a great place to get aftermarket Motorola two way radio accessories. You have your choice of several types or headset/mic combos on there.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Motorola... | Answered on Oct 16, 2011
Check with www.wirelesspro.com or the Motorola TalkAbout store http://www.store.motorola.com/b/2952967011
Best regards.
Motorola... | Answered on Sep 09, 2011
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
You might start by checking the frequency, code and Qt filter (if any), to be certain they are set alike.
Best regards.
Motorola... | Answered on Sep 05, 2011
Go to this website, http://www.ewingenter.com/accessories.htm. Scroll down and look for Charging options & Batteries and just a few lines below that, you will find chargers for your T5530.
A click on YES will be greatly appreciated. Thank you for choosing FixYa!
Motorola... | Answered on Jun 24, 2011
Yes if they are both connected to each other
Motorola... | Answered on Jan 24, 2011
Motorola TalkAbout T5530 2-Way Radio Logo
47 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
get motorola talkabout t5530 charging
  • Radio Communications
