20 Most Recent
Kyocera 1102J22US0 Model FS-4020DN Laser Printer, 47 Pages Per Minute Speed, 250,000 Max Monthly Duty Cycle, 500 Sheet Drawer , 100 Sheet MPT Standard Paper Supply, 8.5 x 14 Max Paper Size, 120 lb Index Max Paper Weight, Fine 1200 mode 1200 x 1200dpi, Fast 1 Questions & Answers
7410 error code
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmly on the drum which is located behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
12/26/2013 8:52:56 PM •
Kyocera...
Answered
on Dec 26, 2013
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
