20 Most Recent
HP ScanJet 8270 Flatbed Scanner Questions & Answers
When i install scanjet
Hi
Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
click hear to download the driver
Paper Jam - as i
Unless you get all of the paper particles out of the intake rollers and gears, you will have existing problems. The speed and motion is effected and there are tiny activation switches that tell the scanner light to make a pass and when to stop. If you cannot clean out left over debris then have a technician do it for you.
I have an 8270. Almost every time I go to use the
Diagnostics modeThe link above should show you how to enter diagnostics mode and test various functions and mechanics to see if it reports an error. Unfortunately it doesn't tell you too much detail about fixes. But if you can at least potentially discover what might not be working perhaps you can chase down a fix for that part.
HP scanjet 8279 displays an
Error code 5 denotes a device failed and requires an arbitrator/administrator. If an installed device requests a resource type and detects that there is no arbitrator, computer users will receive this error code. The arbitrator/administrator redirects the system in a chosen field. It cannot happen if the computer has a firewall or has user restrictions. The administrator does this for security purposes. The system denies admission to other users to protect information and important data.
A user is denied access to some files or program. As a result, the user will not be able to obtain information from certain files nor actions like delete, restore, or edit can be executed.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
Update the driver of the files. Use the click start control panel administrive tools Device Manager scroll to ports(Com<p)+to expand you should see a communication port& Ecp printer port you might see a yellow question mark? right click to uninstall and reinstall the appropriate device. Run wizard in the Add New Hardware in Control Panel
hope this helps
Scanner working but no display
first you check connection cbu to scanner 2. there is a switch in scanner you check on or off that switch should be on 3. did you installed scanner driver sotfwere
HP 8270 does not scan on windows Vista . Could not
Make sure you have the newest vista drivers located
here - also, make sure that the scanner platen is travelling the full length of the scanner, it's not being hung up somewhere causing it to jam. Try to scan while the cover is open to watch the scanner head travel.
