20 Most Recent
Kyocera Color Copier, Km-c2525e Questions & Answers
C2525e touch panel not working
Run a business card between the touch screen and the outside surround. Dirt or dust can make the screen believe that you are constantly touching the screen which will lock up the touchscreen. Try adjusting the screen brightness by adjusting the thumbwheel located at the far top of the display panel.
If this does not rectify the fault then the touchscreen will need to be replaced.
Print job stuck on the queu and dont print
look at bottom R of PC if the printer Symbol is there double click to open. Cancel all jobs, nothing will print if jobs are stuck. Once sleared try going to START -- SETTINGS -- Printer -- the one you are printing fromand right click on it. It will open up a window, go to properties and try printing a test sheet. if it still stays in queue, there is a problem with settings. Do you have more of one of the same printer then try the other one if it prints then delete the one not printing; or delete and reinstall driver.
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
