20 Most Recent
Sony Cyber-shot DSC-H5 Digital Camera Questions & Answers
Error E:62:10
This seems to be a design flaw on the T series. Literally thousands of T series owners have had this problem at some time or the other on their "well-used" camera.
This sounds harsh, and maybe even dangerous, but it's not : use a rubber mallet, or better still, smack the bottom of the camera on smooth hard surface. it fixed my problem.
I have a DSC-H5 sony
It is worth checking your home contents insurance, as cameras, phones etc are normally covered under that type of policy.
Sony Cyber-shot DSC-H5 Digital Camera power button does not work
In today's cameras on off button only give a pulse to processor to switch on.actually camera is on all time technically.only screen is off.Your problem may be flex connection to main board has failed. The group connector for on off, click, Tele, wide, all together forms one connector. Whole part to be replaced by camera technician to save your camera.
Can I download dsc h5 software that is up to date?
Why would you do that? If the camera is not working perfect, you won't be able to put in any firmware. Updates only can be done when the camera is working perfect. Updates only try to change little flaws i the camera. Most of the time only the professional camera and camera's with interchangeable lenses get updates, to make lens corrections possible. For the H5 Sony never released a firmware update.
Turns off right after startup chime
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Sony camarer
Hi Noel, This is not good news unless you are the owner of the local camera shop !! Do you get my drift ???Good luck.Russell
