20 Most Recent Oregon Scientific DS6310 Digital Camera Questions & Answers
I am trying to download
Hello
On your pc, you can get the pictures to your computer by following these steps
1. connect the camera to the computer and wait until its detected
2. if a pop up comes up, close it, close any error messages you may get
3. open My computer or Computer from either desktop or from start menu
4. find the removeable storage device and double click
5. inside you will see a DCIM folder double click on that (or any other similar folder)
6. you may have another folder or two, inside those you will find your pictures.
7. you can right click and select COPY to copy any file or folder from the camera.
8. go to desktop and right click on the background, select Paste, the files are copied or "Downloaded" to your computer on to your desktop.
11/27/2010 9:28:07 AM • Oregon... • Answered on Nov 27, 2010
I jammed my camera lense
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
8/18/2010 8:47:41 PM • Oregon... • Answered on Aug 18, 2010
My Camera Won't Charge!!!
Your batteries are dead. You can buy them buy doing a search for your model number on your camera, and it will tell what batteries to use.
11/30/2009 5:03:44 PM • Oregon... • Answered on Nov 30, 2009
How to open the camera
What brand and model?
1/5/2009 12:34:57 AM • Oregon... • Answered on Jan 05, 2009
Where do i find the serial number?
Possible location of serial number described by frustrated user and responders. https://gregorybeamer.wordpress.com/2010/01/14/oregon-scientific-smart-globe-3-fail-website-and-update/ Quoting from the link above: The serial number of the pen and details I sent to your Parramatta office attention Tee Tran. This is all I can find. >>> >>> 1. Model/item number (located on battery cover of pen) Item No.SG18 >>> 2. Serial code located inside battery compartment of pen device. XXXXXX >>> >>> 3. Access code (6 letter code located in user manual or on CD-Rom cover) >>> Cannot find these but did register online when bought >> then >>> sold the computer with the login. >>> >>> 4. Computer operating system. Windows 7 >>> 5. Country of origin? Not sure what you want the pen says "made in China" >>> >>> The globe has the number XXXXXX stamped in the bottom. >>> Regards Colin On 18/12/2012 9:15 PM, Oregon Scientific Customer Service wrote: > Dear Colin, > > Thank you for contacting Oregon Scientific Customer Support. We are > sorry to hear that you are having issues with your Oregon > Scientific product. > > We received your email inquiry and want to assure you that you will > hear back from us with a detailed response which is typically within > 2-3 business days. Please reply to this email with the following > information for us to provide you the status of the replacement. > > 1) Model # of the unit. > 2) Serial # of the pen located at the battery compartment on white > sticker. > 3) Country where the unit is bought. > > Hope this information helps and should require further assistance, > please feel free to call our customer service hotline at 1300-300-155 > (Toll-Free within AU). Phone and email support are available Monday - > Friday from 9AM to 6PM ADST. Excluding Public Holidays.
10/17/2019 12:46:52 AM • Oregon... • Answered on Oct 17, 2019
I need a manual for an oregon scientific camera model HC18/32127
Fixya does not supply or provide manuals. Look it up on Google, then follow the most useful-looking link
7/28/2017 8:10:12 AM • Oregon... • Answered on Jul 28, 2017
Anyway to get my access number for Oregon Scientific smartglobe, it comes on the cd rom case but that has gone missing
Did you not add it to the list of serial numbers that you keep on your computer for situations such as this ? Maybe contact the original vendor or manufacturer for advice.
4/19/2017 8:58:44 AM • Oregon... • Answered on Apr 19, 2017
0answers
Service center
They are available on eBay
4/19/2014 2:29:51 PM • Oregon... • Answered on Apr 19, 2014
0answers
0answers
Esd 90 instructions
Be the first to answer 12/23/2013 3:04:27 AM • Oregon... • Posted on Dec 23, 2013Be the first to answer
How can i get a new cd to download lost mine that came with the DS6320 model
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
3/6/2013 11:29:08 PM • Oregon... • Answered on Mar 06, 2013
Lost my CD for 3.1
What model camera?If it uses a memory card of some type then you don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said earlier, you can use any photo cataloging program such as Picasa.
3/6/2013 11:23:38 PM • Oregon... • Answered on Mar 06, 2013
0answers
Oregon Scientific DS6310 Digital Camera Logo
5 questions posted
Top Oregon Scientific Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Oregon Scientific Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Oregon Scientific Cameras
Most Popular Question
am trying download
  • Cameras
