20 Most Recent Cobra 22 CHANNEL 2-WAY RADIOS Questions & Answers
The original Sanik batteries have a negative side with about ten mm of metal showing on the side. Trim the plastic off your new batteries to match and the cradle charges again.
Cobra 22 CHANNEL... | Answered on Oct 21, 2016
If you find that the LOCK/MODE button does not correct the problem, I have discovered that the microphone button on the inside has a contact patch mounted on the board. This contact patch is like a piece of scotch tape with a metal dot in the center this slides off to the side and leaves the MIC deppressed continuosly which in turn will lock the radio. I have found this on several radios. Once you center the patch place just a small amount of super glue to the edges and yo will have no more problem
Cobra 22 CHANNEL... | Answered on Feb 04, 2016
Try searching online for the "li6000 service manual" or contact Cobra. The user guide should have contact information and I know that is online.
Cobra 22 CHANNEL... | Answered on Apr 11, 2014
Be sure the Channel and Code are set the same on both radios.
Cobra 22 CHANNEL... | Answered on Nov 07, 2013
You are right there is no adjustment. You can however turn the squelch off and this maybe what is happening to you.
To turn the squelch off you press and hold the button that is just below the push-to-talk button for at least 5 seconds.
To turn the squelch back on, you either press (less than 5 sec.) and the same button or change channels.
When talking with a specific party or group, you should use the tone coded squelch (CTCSS) and that will mitigate the noise if you are not already doing that.
Cobra 22 CHANNEL... | Answered on Nov 15, 2012
Please provide the model number and I will try to link you to the operating guide for your radio . . .
Cobra 22 CHANNEL... | Answered on Jan 04, 2011
Some Cobra radios have a selectable "Roger Beep" while others do not. Without the model number I can't tell if yours can be switched off or not, but if the option is not mentioned in your operating instructions the beep is permanently ON.
Cobra 22 CHANNEL... | Answered on Dec 08, 2010
These are FRS/GMRS radios. You may have different privacy codes set on the radios. If a receiving radio has a different privacy code than a transmitting radio, you will not hear the transmission. This allows many people to share the 22 channels, but only hear transmission from their party.
Cobra 22 CHANNEL... | Answered on Nov 11, 2010
This could be a low power warning. Make sure that your batteries are fresh and fully charged, and that the contacts on the batteries and inside the radio's battery compartment are clean and free of corrosion.
Bill B
Cobra 22 CHANNEL... | Answered on Jun 02, 2010
Channels 8 through 14 are low-power FRS license-free channels. Operation on any other channel requires a GMRS station license issued by the FCC. Unauthorized/unlicensed use of the GMRS frequencies can result in stiff fines and confiscation of radio equipment.
Bill B
WQJV930
Cobra 22 CHANNEL... | Answered on Apr 27, 2010
You didn't provide your model number, but you should be able to locate it by following this link:
http://www.cobra.com/pages/product-manuals#CB%20Radios
If your model is listed you can download/print the manual.
Cobra 22 CHANNEL... | Answered on Dec 05, 2009
Cobra 22 CHANNEL 2-WAY RADIOS Logo
Popular Tags
38 questions posted
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
cobra pr4700wx none controls work
  • Radio Communications
