20 Most Recent Krups FEP 4 4-Slice Toaster Questions & Answers
I took all the screws
After taking out all the screws usually you would need to remove the dial knobs on the unit and after removing them use a flat head screwdriver to pry the unit open as always the screws are just there to act as support for the holding of the unit together. Usually they are held with clips in place to hold the entire unit apart from the screws. So get a small flat screwdriver put it in the space where the unit is supposed to split in 2 and pry it open slowly to avoid cable disconnections.
Hope this support has been helpful?
Thank you for visiting FixYa.
7/18/2011 5:37:18 AM • Krups FEP 4... • Answered on Jul 18, 2011
How do I clean inside the toaster? Not just the
You can't clean the inside without a real possibility of damaging the element(s). Hold it upside down over the sink or outside and shake to remove all the stubborn bits. If you poke around inside you will most likely damage it. If you decide to ignore my advice then don't forget to DISCONNECT it first or you risk electric shock!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
2/15/2011 10:01:26 PM • Krups FEP 4... • Answered on Feb 15, 2011
tip
Krups Blender 577 replacement of rubber coupling
Krups Blender 577 - first try it not easy but next time it will be. Replacing the rubber coubling is extremely difficult with this model. After almost destroying the air in/outtake grill on the side in pursuit of a good lock of the axe, I tried so hard to use a nose plier to grab the post and unscrew the coupling counter-clockwise but it just didn't fit (it needs to be long and narrow/needle like). So I ended up cutting off rubber on the coupling and also cutting of plastic from the black plastic cover which is just under the rubber coupling. In the end I was able to cut that plastic and remove it so that I could actually take off the whole casing (you need a torx 20 with a hole in it to unsrew the 4 bits at the bottom underneath the rubber stands) with the rubber coupling still attached and detach two power cables so that I had much more space to properly grab the post and then it was very very easy to unscrew it counter-clockwise. But up until then I lost my insanity twice :-). Now I know how to so the next time will be easier.
KRUPS FOOD SLICER MODEL 213 HAS BEEN STORED FOR A COUPLE YEARS AND NOW THE BLADE WONT TURN. wHAT TO DO?
Thoroughly clean it then try a little bit of oil.
1/2/2018 7:24:28 PM • Krups Kitchen... • Answered on Jan 02, 2018
KRUPS KJ502D51 Stainless Steel Triple Basket Deep Fryer ********** Just bought used . Has error 2 on display
Here is the manual in case you do not have it:. Scroll down until you find "Documentation" and then download the instructions. http://www.krupsusa.com/KITCHEN-APPLIANCES/DEEP-FRYERS/4-5L-Deep-Fryer-with-3-Baskets-KJ502D51/p/8000035750 As far as the error code goes, Krups does not list anything. However, there is a reset button on this unit (see the manual), it may need deep cleaning, OR the internal battery needs to be replaced. If none of that works contact Krups (number inside the manual or on the website) customer support and see what they say.
12/7/2017 5:44:17 PM • Krups Kitchen... • Answered on Dec 07, 2017
0answers
I just bought a rice cooker at a garage sale. It had no instruction manual
To make rice, remove the trivet if you have one as this is only for steaming food. Wash rice to get rid of excess starch and put in pan. Then add the same amount of water as rice (2 cups water to 2 cups rice etc.) then shut lid and switch on and leave it. Once it has switched off do not open the lid for a further 20 minutes (the machine will keep the rice warm do not worry) Stir rice and serve. Most rice cookers will keep the rice warm for a couple of hours. If you find the rice is a bit dry then add a little bit more water, the amount of water really depends on the quality of rice used.
9/21/2014 11:36:45 AM • Krups Kitchen... • Answered on Sep 21, 2014
0answers
Krups FEP 4 4-Slice Toaster Logo
4 questions posted
Top Krups Kitchen Appliances - Others Experts
john h
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Krups Kitchen Appliances - Others
Most Popular Question
took all screws
  • Kitchen Appliances - Others
