20 Most Recent Gateway FPD1975 19" LCD Monitor Questions & Answers
Gateway mx3215 freezing on init boot
Corrupted driver or faulty hardware perhaps.
5/8/2017 2:49:26 AM • Gateway FPD1975... • Answered on May 08, 2017
4answers
EzTune problem with lost PIN number to disable Theft Deterence
Whatever you do - DON'T CONTACT GATEWAY. I am in the UK, and the Gateway support number is only available 9 - 5 (funny 'cos I'm at work then and can't access my PC), so I filled in the technical support form - waited 2 days for a reply only to be told they don't support third party software.
I had an online chat with US Gateway support - only to be told the same thing - alternatively, pay them silly amounts of money and phone the US and they will fix the problem.
The solution is to visit Portrait Displays (software developers) website and complete an online form with your problem. (This form prompts as to whether you have already contacted Gateway - so maybe they are monitoring the adequacy of Gateway support. The support from Portrait has been brilliant.
Unplug the cable from your monitor and then hold the power button while you plug the cable back in. When the monitor is fully restored,
release the power button and an anti-theft box will appear, prompting you to press the menu button at the side of your monitor. Press the menu button and you will be given a 3-digit code. Portrait need this code to give you an unlock code. Once you have the unlock code you can remove the anti-theft option.
1/3/2016 3:08:23 AM • Gateway FPD1975... • Answered on Jan 03, 2016
0answers
5answers
Menu Screen
so sorry, not a solution but the same thing is happening to me. gateway emachine model LE1799
11/26/2012 4:13:32 PM • Gateway FPD1975... • Answered on Nov 26, 2012
Eztune is not accepting my
Unplug it from the wall for 40Min, and that should reset back to normal.
8/17/2011 7:12:46 PM • Gateway FPD1975... • Answered on Aug 17, 2011
0answers
2answers
Lock out of my computer through eztune-
Call Gateway @1-800-gateway. They will tell you to unplug the monitor, plug it back in while holding the power button. A screen will apear giving you a code number. The gateway rep. asks for the code number and then gives you a code number to unlock your screen.
4/19/2011 4:35:17 AM • Gateway FPD1975... • Answered on Apr 19, 2011
2answers
I have a gateway FPD1975W
From your description you have a power supply problem, usually caused by defective capacitors, sometimes they will bulge at the top indicating an open condition. If you decide to repair check the inverter board that powers the back lights behind the screen, because they are also prone to bad caps.
2/18/2011 3:03:48 AM • Gateway FPD1975... • Answered on Feb 18, 2011
My monitor wont stay on.
Navigate to the control panel and double click power options. On the Power Schemes Tab ensure that all the fields are set to NEVER.
This will keep your monitor on all the time.
Thumbs up!
damnor01
2/1/2011 9:37:55 PM • Gateway FPD1975... • Answered on Feb 01, 2011
2answers
Monitor comes on saying protected
First download Eztune software from abovce link uninstall old and install from new download.For getting pin you need buy it's license copy from it's menufecturer web sites. Buy it's pin then you can use it. Let me know if you need further assistance. Thanks for using FixYa.
12/3/2010 8:57:19 PM • Gateway FPD1975... • Answered on Dec 03, 2010
Gateway monitor 22"
I think the guys at www.securedata.biz have a fix for that.
7/11/2010 7:29:33 PM • Gateway FPD1975... • Answered on Jul 11, 2010
Goes into standby and will not come up
Check the power supply section first fo bad caps, but before doing that, try it on another PC first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Gateway and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
6/16/2010 8:06:30 PM • Gateway FPD1975... • Answered on Jun 16, 2010
2answers
My Son threw his sippy
Did the screen get cracked?
If so, I would most likely suggest replacement than a repair.
The LCD panels are not cheap.
Sorry for the bad news.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
3/15/2010 5:11:31 PM • Gateway FPD1975... • Answered on Mar 15, 2010
Every hour my screen goes
first take a look into the add remove software from the control panel to see if there is any program that is named like this ...and remove it ...it might came with the monitor driver ..and it is set in the wrong time ....
but ..the actual problem is that you have set the power savings from the desktop properties...so ..right click on desktop ..go to screen saver ..somewhere in the lower place ya have something like power manager ...go there and remove any power savings ...just place them to never shut down .. and it will stay on ...
12/20/2009 12:44:20 PM • Gateway FPD1975... • Answered on Dec 20, 2009
Power supply where and how much?
call your dealer... ask him about where u can buy that one... thats the only way u can find information about the price..
hope you can call your dealer
with regard,
jabems
11/1/2009 1:47:38 PM • Gateway FPD1975... • Answered on Nov 01, 2009
I need a driver for my FPD1975 I am using it on
Hi
Please follow the link to download the drivers:
http://www.bioticaindia.com/fpd1975w.html
8/3/2009 4:38:58 AM • Gateway FPD1975... • Answered on Aug 03, 2009
Welcome Screen Blinking Gateway Monitor
I would suggest that you re-install the disc. that comes with the screen.
If that doesn't work, check to see that your video card is working correctly.
5/26/2009 8:27:16 PM • Gateway FPD1975... • Answered on May 26, 2009
Monitor blinking on off
plz tell me,
you screen is blinking or a on of led.
5/1/2009 11:37:17 AM • Gateway FPD1975... • Answered on May 01, 2009
Blinking power up button
Its a powersupply problem in your LCD screen, i had the same thing happen to me- i found a site where you can fix it yourself- heres the link. http://computerguru365.blogspot.com/2008/01/fix-that-lcd-flat-panel-monitor.html I did it and it works.
4/1/2009 9:21:47 PM • Gateway FPD1975... • Answered on Apr 01, 2009
Gateway FPD1975 19" LCD Monitor Logo
37 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
power supply much
  • Computers & Internet
