20 Most Recent
Galaxy Radios DX- 88HL Base CB Radio Questions & Answers
No sound
It must be a bad internal speaker, but also check the external speaker jack for broken solder. Good Luck
Ed
NC Electronic
Mills, Wyoming
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Hi, my 88 drifts off
- Is it drifting off frequency by the radios meter or an external meter. If its the radios meter then hook up a meter externally.
Galaxy 88hl frequency display only has decimal point, channel readout fine
on the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Haven't used my dx-88hl cb for years. what d9 i
I'm not going to be corrected on this as i'm tempted to say A or C and sometime D. Instead i would say switch channel to 19 then watch frequency counter as you change band selector until you find 27.185 and you have arrived.
Short on rf gain, witch pod?
in order to do this you will need a scope,an rf signal generator and an AF vtvm also a dummy load. These are the pods you wanted to know about. They must be done in order so here goes L8 to max then L7,9,11,12,13,52,3,4,5 now go back to L8 and make sure you are still at max on scope Then set vr1 and 4 .go to L14 and 15 .Now go to vr 2 and 3 .now to L1 and 2 check for overall with L6 . This is a brief reading of what you do to get what you are looking for.If you still want to do it or have a tech do it then go to www.cbtricks.com . Look up the letter P the search for president then Grant XL click on it and follow the directions for a receive alignment.
How do i set my galaxy dx 88 hl so the talkback is on all the time
turn the talkback knob to the right and push it in to engage talkback.when you get the volume you want leave it alone .Now key the mic.You will probably hear a squeal coming from the speaker.Now turn the volume down on the talkback knob until the squeal goes away.If you run your RF gain wide open it may squeal also.
No audio on receve
could be a lot of things. How your S.W.R. if its bad your radio is not performing properly. you could have a final problem. Check the voltage going to the audio IC. Do you have a service manual,you're going to need one.If you don't want to go through the process of elimination then maybe you should take it to a tech.
My galaxy dx 88 hl works great but the talk back
if you hooked it up its wrong but I assume you didn't.First of all talkback is a feature that allows you to hear your voiceand you don't5 need a radio check because you can tell by your own voice how your radio sounds if you want it to work on am you need to attach a 33ohm resistor from the positive to the neg of the external and pa plug ins. the talkback will be on all the time by the way.
