20 Most Recent
Dell E193FPp 19" TFT LCD Flat Panel Monitor Questions & Answers
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
My monitor always closes after
It canbe caps, transistors, cold solder joints, etc. You can try troubleshoot it down to components level or replace the board.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
Replacement board: http://www.lcdrepair.us
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Just plugged a Dell E193FP monitor into my
The computer is not able to communicate with the hardware properly. It can be solved installing the Video drivers (The video card drivers AND the display drivers).
Check for updates with the manufacturer of the video driver.
To determine what Video card your computer has, just right click in MY PC - MANAGE - DEVICE MANAGER and click Video, check properties.
Good luck.
How to control the brightness of Dell TFT monitor
That's the buttonsd on the monitor, not the PC.
Press the [menu] button on th emonitor.
The screen will show the labels of the buttons now.
press the "arrow" to position to the brightness setting (the "sun" icon)
press the minus [-] button to dim
Press [Menu] to save & exit the OSD (on screen Display)
No power to unit
well first thing if its like mine the power cord is detachable unplug it from the tv and use a tester on it to see if power is coming thru if it is (and more than likely it is) its the psu (power supply unit)
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
