20 Most Recent Dell E193FPC 19" TFT LCD Flat Panel Monitor Questions & Answers
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen. As there are high voltages on inverters, this is really a job for a repair shop.
12/11/2013 12:09:35 PM • Dell E193FPC 19"... • Answered on Dec 11, 2013
0answers
Screen resolution
More then likely this is all it can handle form your PC. Two things, I would check see what the screen can handle and see what your video card or chip can put out.
9/11/2012 2:58:01 PM • Dell E193FPC 19"... • Answered on Sep 11, 2012
2answers
I recently purchased a used
Have you tried lowering the resolution of your computer? Better yet you can try booting up the pc in safe mode. If that work, then probably the problem is that the monitor does not support high resolution.
You can also check if your video cables are properly inserted to the correct slots. Also check if your video cables are damaged. Thank you.
9/16/2011 1:01:03 PM • Dell E193FPC 19"... • Answered on Sep 16, 2011
2answers
Dell E193FPC monitor When the computor is switched
Welcome to Fixya. No picture can be cause by Video Card, Video Cable, Memory Module (RAM), or a Bad Monitor. Provided below are the steps on how to check each part.
Monitor and Video Cable: If you have another computer you can try to connect the monitor and see if it work.
Video Card: If the computer is using a video card, if you have a spare card or you can try to use the video card to a different computer and see if it will works.
Memory Module or RAM: Check how many memory stick you have. If you have 2 try to transfer it to a different slot use the module 1 at a time or try a working memory module on the computer or use the memory module to a different computer to isolate the issue.
Please let me know what happen so that we can continue troubleshooting. Thanks
9/4/2011 12:42:59 AM • Dell E193FPC 19"... • Answered on Sep 04, 2011
My Dell moniter is a
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
8/18/2011 3:23:55 AM • Dell E193FPC 19"... • Answered on Aug 18, 2011
My monitor Dell E193FPc is
That means it has shorted out transistors in the inverter circuits.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20E193FP/
Yoiu also need to check the solder joints, caps in the power supply/Inverter board.
Replacement board: http://www.lcdrepair.us
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
7/9/2011 9:52:16 PM • Dell E193FPC 19"... • Answered on Jul 09, 2011
The monitor comes on shortly then goes off but it
You need to check for caps (bulging/leaking top), shorted transistors, fuse, and possibly the lamp assemblies.
See example here: http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20E193FP/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Replacement board: http://www.lcdrepair.us
7/8/2011 7:08:17 AM • Dell E193FPC 19"... • Answered on Jul 08, 2011
My flat pc monitor has a punchsure in the screen!
Sorry, there is no fix for a punctured screen. It is amazing that it is still working at all.
It will not keep working for long, I am sorry to say. LCD means Liquid Crystal Display. As the liquids disperse through capillary action, the "hole" in the picture will get larger. Eventually, enough of the microscopic transistors that drive the liquid crystals from light to dark state will fail to cause the entire screen to shut down.
There is no way to tell how long your screen will continue to work.... for all I know, it may have failed when I started typing an answer to your question.... it may last for minutes, days, maybe even weeks.
If you were very lucky and only punctured the outer thin-film protective glass layer, it may keep on working fine. You will be able to tell if this is the case if there is no dark spot in the screen where it got punctured.
Good Luck with it! Sorry the news is not better, but in any case, Thank You for using FixYa!
5/8/2011 6:16:37 AM • Dell E193FPC 19"... • Answered on May 08, 2011
Dell E193FPC 19" monitor display
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
5/1/2011 1:44:36 AM • Dell E193FPC 19"... • Answered on May 01, 2011
0answers
When pushing on button, screen lights up for 1
It may have components failure such as the caps, transistors, fuse, etc:
http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
2/18/2011 5:14:03 PM • Dell E193FPC 19"... • Answered on Feb 18, 2011
How to connect monotor with
Hello
44963.jpg Connect this connector to LCD Monitor and restart your system, it will detect your monitor by itself if not click http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors to get help from Microsoft.
Hope this helps if so do rate the solution
Good Luck
1/5/2011 10:21:41 AM • Dell E193FPC 19"... • Answered on Jan 05, 2011
The glass of the monitor
You have to replace the whole LCD panel assembly, not worth it.
The glass that you broke is the TFT LCD panel.
You can GOOGLE the part number as printed on the back of the LCD panel assembly to see if you can get one for this old monitor.
12/28/2010 7:38:40 AM • Dell E193FPC 19"... • Answered on Dec 28, 2010
The power button got stuck and the monitor won't
It may have broken actuator or the arm for the button is now broken, it is very poor design, I cannot locate anyone that sell this assembly yet. You may be out of luck, what I have done is to remove the button and use paper clip to actuate the switch.
12/28/2010 7:13:37 AM • Dell E193FPC 19"... • Answered on Dec 28, 2010
Screen switches off after about 2 seconds
See E193 album.
12/13/2010 4:13:31 AM • Dell E193FPC 19"... • Answered on Dec 13, 2010
Monitor keeps shuting down power button flashes
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.Replacement board: http://www.lcdrepair.us
10/17/2010 10:45:27 PM • Dell E193FPC 19"... • Answered on Oct 17, 2010
Dell E193FPC 19" TFT LCD Flat Panel Monitor Logo
Popular Tags
44 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
bottom green flashing not vision
  • Computers & Internet
