20 Most Recent Galaxy Radios DX-99V 40-Channels Base CB Radio Questions & Answers
turn vr-14 all the way to the right,then all the way to the left. watch your meter and which ever way moves the needle more thats the position to leave it in.
Galaxy Radios... | Answered on Jan 22, 2016
it is either a bad soilder on your crystal or your crystal is going bad
Galaxy Radios... | Answered on Nov 12, 2015
could be a strong signal overpowering the unit and causing a continious power on check with those in the area to see if they have the same problem.
Galaxy Radios... | Answered on Sep 13, 2015
check your mic connections ,make sure there are no broken wires.
prefferably on . sq to point that radio starts to hiss . then RF gain about 3/4 open along with power gain . clarifier set to channel you are monitering . volume your choice.
Galaxy Radios... | Answered on Mar 16, 2015
cobra ,is about the easiest to work on and galaxy is good RCI , Midland is secretive , the rest are in the eye of the beholder.
Need more info ...but these 99v is notorious for cracking traces on the board. The frequency counter roams all over when this happens . It wont let it key up or receive. It needs a good tech to find it.
Galaxy Radios... | Answered on Mar 10, 2015
check your voltages, bring coffee you are going to be a while.
Galaxy Radios... | Answered on Feb 23, 2015
Its a lot more work then you think but it can be done . you should do a serch for a service manual online and work off of it.
Galaxy Radios... | Answered on Jan 12, 2015
you either bought it used or you played with the inside because if the alc is all the way open then you have been inside it.got a watt meter to turn up the power.you will also need a volt meter. take it to some one that knows what to do and let them fix it.
Galaxy Radios... | Answered on Nov 29, 2014
how about galaxy.they still stock everything.
turn the volume selector up a little at a time and see what you get.this could be a voltage problem
you will be better off taking this to a tech considering it is a ham radio also. he can set the freq and put it on a distortion meter also to find out the problem.
there is a vr for turning it up and the same one turns it down
Galaxy Radios... | Answered on Sep 01, 2014
www.cbtricks.com
Galaxy Radios... | Answered on Aug 09, 2014
the voltage regulator in the freq.counter board is bed and probably a diode common problem that need to go to a professional not a DIY easy job
Galaxy Radios... | Answered on Feb 28, 2013
the meter probley is bad common problem on this radio
c b tricks.com
Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
62 questions posted
Top Galaxy Radios Radio Communications Experts
Marvin
Marvin
Mike Charette
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Galaxy Radios Radio Communications
Most Popular Question
will diesel 360 3 mic ork galaxy dx99v
  • Radio Communications
