20 Most Recent
Sony LBT-ZX6 Shelf System Questions & Answers
Where is my output ic situated
the out put ic is situated inside right side wen the unit front is facing you ,you cant miss it its bolted on a alumium heatsink silver, it has a number stk 412 150 written on it,,,
Basic HiFi troubleshooting.
First things first. The unit doesn't switch on.
- Is it plugged in?
- Is the fuse blown?
- Does it look like it's suffered damage?
It switches on, but won't play anything / the lights come on, but no sound.
- We'll start at connections. Is your MP3 player/ iPod/ CD player/ record deck plugged in correctly?
- Are the speakers plugged in correctly/ at all?
- Is it in protection mode - this is a pretty standard thing now, where the amplifier tries to deliver more than it's rated current (ie, into a short circuit), and it cuts out. The only way to fix this is to take it to a local hifi shop, who will reset it (there's usually a small fee involved). The unit will be fine after that.
------- There is no bass. ----------
A few causes for this, so there's a few solutions.
- The speakers are out of phase. This is where one speaker is wired normally, one is wired in reverse. The bass from each speaker is "opposite" and would cancel out. To solve this, Make sure the + on the speaker is connected to the + on the amplifier. There's usually a stripe on the cable to help you determine this.
Cause # 2
The eq settings on your ipod/ unit have been messed with.
Set all the equiliser settings to flat, then readjust them to taste.
Cause # 3 (nasty one)
You've blown a woofer. The explanation is this - the speakers have taken in too much power, the bass unit has got too hot and the glue holding the coil in place has melted. Usually, the woofer can't be physically pushed when this happens. To solve this, it's new speaker time. An alternative is to see if you can get a recone kit for said speaker, and try to fix the voicecoil yourself. This isn't recommended to those who are new to the idea.
I hope this helps the reader.
Chris
I have a Sony LBT-ZX6
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealersip.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I WANT TO HOOKUP MY
Can I have the make and model of the tv so that I can ascertain what inputs it has behind it? The reason for this is coz the surrond system input to be built into the tv reciever otherwise you will just get mono if you plug it into the av jack.
Good morning! I wish to plug our television
You may be able to avoid messing with the optical output completely, if the TV has a headphone output, in which case, a phono-3.5mm jack adaptor will sort you out nicely.
If it has to be optical, I expect you can buy adaptors for this aswell, but I'd expect it to be more expensive.
Most local electronics stores will sell these. Radioshack is a good example. Also, you could look around on the internet.
