20 Most Recent
Sony Handycam DCR-DVD405 Camcorder Questions & Answers
My SONY DCR-DVD405 Viewfinder has
There is nothing user friendly on these, if your not factory trained on this type of repair then it should be done by someone who is. The view finder is a small LCD and is not meant to be repaired, but they can be replaced. Get an estimate and decide if you want to repair or live without it,
How do you delete videos
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
My touch screen or play/edit
There is connecting flexible wire between LCD board and camcorder main board, if that flexible wire got cracked, camcorder touch buttons stop working.
Please replace connecting flexible wire. Let me know exact model of camcorder to provide you flexible wire part number info.
Thanks.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
