20 Most Recent
HP Compaq Computer Speakers Questions & Answers
Cannot find output jack
The out put jack in some speakers there aren't any but it matters what kind of speakers. For example I have more or less portable speakers. And professional speakers it is different.
6/2/2012 6:02:17 PM •
HP Compaq...
Answered
on Jun 02, 2012
I have laptop Compaq nx
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you
9/10/2011 8:07:41 PM •
HP Compaq...
Answered
on Sep 10, 2011
I have windows 7 in
please up date your sound driver online and try again
please vote me and rate it
9/10/2011 12:34:29 PM •
HP Compaq...
Answered
on Sep 10, 2011
Laptop speakers are not working.
also
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
8/29/2011 4:06:08 AM •
HP Compaq...
Answered
on Aug 29, 2011
After installation of Windows XP
A fresh installation of Windows usually doesn't have support for integrated sound, so you'll need to install the sound driver software. You can download what you need from HP. "CQ60" is a big family of models, so you'll need to pick your specific model from
this page. Then you'll be able to pick the drivers you need for your computer. You should also download and install the video drivers as well. This will make sure you get the full performance from your computer's video.
8/12/2011 10:31:18 PM •
HP Compaq...
Answered
on Aug 12, 2011
The speakers of my lap
this happens when either the connections of the speaker get loose or speakers goes wrong in any case take your laptop to the technician he will rectify it
7/30/2011 2:25:11 PM •
HP Compaq...
Answered
on Jul 30, 2011
I have problem in internal
Hi! Welcome to www.fixya.com.
1. Check if you have red x mark on your speaker option.
2. Check if control panel then sound if speaker is your default settings.
3. Type device manager on the start search and check on
sound driver. If there is a exclamation point
4. You need to get the righ driver for your audio
5. Check out this website and put your exact model to get audio driver.
6. You can check whether your sound is good if you plug in a head set to test it.
Hope this resolution fix the problem on your computer.
Thanks for contacting Fixya. Bye for now.
7/19/2011 12:02:15 PM •
HP Compaq...
Answered
on Jul 19, 2011
No sound
hello
May you need a drivers of sound . look near to the clocl if is there the volume icon
=if is there that mean you don't need the driver
= if is theren't that mean you need the driver
if you need the
driver you can download it from here
the go to drives back up page
and thank you
7/15/2011 7:15:32 PM •
HP Compaq...
Answered
on Jul 15, 2011
