20 Most Recent HP Compaq JBL Pro (401508-001) Computer Speakers Questions & Answers
3answers
Disassembling the speakers - Compaq Jbl Pro (401508-001)
pry the speaker cover slowly using small screw driver on the side,,it has four locks giong thru..its position two at the top and two at the bottom..it is line w/ the volume control and headset..be careful not to break the speaker cover.then remove the four screws inside the hole where the speaker cover is position.remove also the rubber protector beneath the speaker or under the speaker..it has a lock beneath the rubber covering it..push the lock slowly, be careful not to break it.but even if you break it,it will do nothing..now insert finger in the hole and pull the face or pry w/ small screw driver and lift...
3/22/2021 3:30:50 PM • HP Compaq JBL... • Answered on Mar 22, 2021
I have a JBL Pro Premium Computer Speaker System
Hi, It seems that the varistor have bad contact. You can try to open the sub/speaker and clean the dust inside, maybe helps. Other possibility you find the varistor and change it, but it required a little bit material and time.
5/30/2017 6:07:45 PM • HP Compaq JBL... • Answered on May 30, 2017
Distortion
try mounting another speaker to see if the computer still sounds bad if it still does than the problem is in your soundblaster card or expension slot
4/19/2014 5:49:43 PM • HP Compaq JBL... • Answered on Apr 19, 2014
0answers
Poor sound
Be the first to answer 4/19/2014 3:08:40 AM • HP Compaq JBL... • Posted on Apr 19, 2014Be the first to answer
I HAVE THE PICTURED SPEAKERS WITH A 4.5 VOLT POWER SUPPLY. THE SPEAKERS LOSE QUALITY AT HIGHER VOLUME. DO I HAVE THE PROPER POWER SUPPLY, OR ARE THE SPEAKERS BAD?
Hi , Nothing seems bad to me in your case since you get what you have for your money . Cheap stuff always gives distorsion at high volume .Youl'll get good results with a 2.1 set of min. 25 W power , meaning 15W for the sub and 2x5 W for the satellites . Regards .
1/31/2014 6:31:16 PM • HP Compaq JBL... • Answered on Jan 31, 2014
Need power supply
Take a look where the power-adapter connects into the speakers. Also, look on the "brick" of the power-adapter.
Look for 'AC' or 'DC'.
Look for '6V' or '9V' or '12V' or '18V'.
Look for the Amperage rating.
If 'DC', look for the small pictograms, either:
* ring-positive-post-negative, or,
* ring-negative-post-positive
With that information, check Thrift Stores, and then check the "big-box" computer stores.
10/23/2011 2:50:15 AM • HP Compaq JBL... • Answered on Oct 23, 2011
My laptop's(Comaq 610) speaker could
Hi ,
Yes you can always change , but first , lets look at thhe sound card drivers ,
1st- click on the start button and go to the control panel on the left , ckick that icon , than find device manager and open that , you will see all the devices that are install on the menu ,
2nd- scroll doen th sound ., viedo and game controllers , click on that icon to see your sound card driver , RIGHT click on your sounf card and scroll down the prop. and click on that , this will bring up a page that will tell you if your card is working or if there s a conflick ........try this first and tell me the results and i will advise further ........................Roy
9/21/2011 1:32:18 PM • HP Compaq JBL... • Answered on Sep 21, 2011
0answers
No sound comming out of
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer make sure you have an earth ******** before touching any parts inside your computer hope this helps
5/28/2011 4:13:19 PM • HP Compaq JBL... • Answered on May 28, 2011
My jbl platinum speakers doesnt
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps don
3/3/2011 3:06:49 PM • HP Compaq JBL... • Answered on Mar 03, 2011
Dear, discription input and output speakers
Your query is not clear.Can you please write in details?
2/5/2011 9:35:09 AM • HP Compaq JBL... • Answered on Feb 05, 2011
The problem with sound (cod
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the value FailReasonString in its hardware key, then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
  • Device driver conflicts
  • Corrupt or damaged software files
  • Malfunctioning hardware
  • Corrupt or damaged system registry
  • Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent most system errors. Some of the tasks that you can perform to prevent system errors are listed below:
  • Keep your operating system, device drivers, and software applications updated with the latest hot fixes, security releases, and updates.
  • Run regular antivirus and anti spyware scans to keep your PC free from harmful and disastrous malware. Always keep these software updated with the latest security releases so that your system is always protected against malware infections.
  • Avoid opening attachments of unsolicited emails and visiting dubious websites.
  • Do not download freeware and shareware from websites whose authenticity you aren't sure of.
  • Be very careful while downloading ActiveX controls from various websites. ActiveX controls provide their master with complete control over your system and therefore, a malicious ActiveX control can cause severe damage to your system and may also enable a hacker to steal your personal information.
  • Last but not least, perform regular registry maintenance to ensure that your registry is free from errors. 90% of all system errors are connected to the system registry in one way or another. You can easily perform registry maintenance with the help of a registry cleaner such as RegGenie. This software will provide you with a simple-to-use graphical interface and enable you to scan and clean registry errors in just a few mouse clicks.
System errors are common on Windows systems and can occur due to a number of reasons, including problems with device drivers, hardware, software applications, and the system registry. Code 10 is one such system error that occurs due to problems with a device driver. You can fix this error by updating the faulty device driver. Preventive maintenance with the help of antivirus software, registry cleaners, and a certain amount of vigilance while working on the Internet can help you keep your PC free from system errors.
Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
1/15/2011 6:42:19 PM • HP Compaq JBL... • Answered on Jan 15, 2011
Where cani get new ones
Ebay is the best source I know of.
1/14/2011 3:11:23 AM • HP Compaq JBL... • Answered on Jan 14, 2011
Well i own a dell
HI
Speaker nothing to do with your screen if your not getting sound there will be some problem with CPU only becoz speaker are working separately
12/23/2010 2:50:42 AM • HP Compaq JBL... • Answered on Dec 23, 2010
How do you attatch the speaker unit to computer
The speakers hook up in the earphone jack, it often is a green plug. Get speakers with a subwoofer and you get really great, full sound. A subswoofer does not mean LOUD, but rather full, unless you are a teenager.
10/12/2010 4:11:58 PM • HP Compaq JBL... • Answered on Oct 12, 2010
HP Compaq JBL Pro (401508-001) Computer Speakers Logo
49 questions posted
Top HP Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • HP Audio Players & Recorders
Most Popular Question
laptop 39 s comaq 610 speaker could
  • Audio Players & Recorders
