20 Most Recent
Sanyo EM-G2585W Microwave Oven Questions & Answers
User manual
Call the company who manufactures your a Sanyo Convection and ask them to send you a user manual guide. Make sure you give them the grill model number.
My microwave part is not working but the grill
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Micro is turning on ok and working but not heating
How old is your m wave? Sounds like you need to replace it .You can get a new one from Wal mart for under 75.00.and that will get you the big 1 sq.ft one..I once broke the plate in my m/wave and believe it or not they wanted more for the new plate than I paid for the M/wave BEFORE you do that check your power level settings perhaps it was turned down
Sanyo EM-G2585W 800 Watts Microwave Oven
It's possible that the unit is overheating, and shutting itself down to make sure that it doesn't melt or burn. Do you have it against a wall, or in a cabinet where the unit cannot vent? Is there a fan? Is it working?
--j.
Door is jammed
It's likely that the door open lever is broken.
It is located behind the control panel, right behind and in contact with the door open button.
With power unplugged, you or a friend can remove the screws in the outer wrapper, then lieft up and back to remove it.
You can see then the door open button / lever area and you should be able to figure out where to push with a dull knife to pop the door open.
Then you can see about getting replacement parts.
If your unit has a model tag, it may have company contact information, or you can contact the place you got it (phone is best) to see if you can get parts at all.
This info may or may not be correct:
"Cascade's head office is located on Auckland's North Harbour"
15 Ra Ora Drive
East Tamaki
Auckland
PO BOX 58960
Greenmount
Auckland
(09) 2739136
Fax: (09) 2739137
http://www.cascorp.com/
Good luck.
My Sanyo Microwave does not heat up
As it is an older model, I would suspect the magnetron and or capacitor. Maybe the fuse has blown but it will happen again if you just replace it.
Where can I get my door fixed
I would find someone that repairs and fixes small appliances then. I would search on Google and Yahoo small appliance repairs then.
