20 Most Recent Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher Questions & Answers
Have you tried Steel Meister? It is available at Home Depot, and it works on all my stainless appliances.
Bosch 24 in.... | Answered on Dec 21, 2017
1) Test any fuse blown or c breaker inside,retight very well any wires connectors!
2) IF remain the same problem.the board is faulty.
3) Replace the board call to the factory if you can get some rebate from old board vs new board.
God bless you
Bosch 24 in.... | Answered on May 15, 2012
Dear Sir:
This is a electronic problem you must Snap the new board, and replace it with carefully. Turn off the panel, and proceed.
Call to the factory and get answer if you can get some rebate for return the old board defective vs new one.
God bless you
Hello, herb
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Bosch 24 in.... | Answered on Oct 27, 2011
by burn your own hand
Bosch 24 in.... | Answered on Jan 16, 2011
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Bosch 24 in.... | Answered on Oct 30, 2010
think this means that your water pressure is not high enough for rinsing to be completed 100%. do you have low water pressure.
Bosch 24 in.... | Answered on Jun 19, 2010
the code you are getting is a drain pump issue.use a wet dry shop vac attach it to the end of the drain hose to remove the water.then check your drain pump for any kind of obsrtutions.
Also make sure the if it attached to a garbage disposal that the knock out plug has been removed from the disposal unit.
you can try and disconnect the hose and stick it in a bucket and find out if the unit will dain that way.you may need to replace the drain pump
Bosch 24 in.... | Answered on May 28, 2010
error code 01 means interrupted heating phase or no heat on final rinse if machine is heating on beginning of wash this will be a blocked transfer hose or pressure chamber need to remove left hand side panel to access and base panel to access transfer hose it will be full of food deposits messing up water fill cycles these machines will only heat correctly when wash water is at correct level. the wash perfprmance will suffer till this is done.
Bosch 24 in.... | Answered on May 27, 2010
no it wouldn't, this is a common failure on bosch dishwashers. you have either a bad control or a bad touch membrane. parts are fairly expensive and only way to know for sure is to replace one. I usually find that the control panel is at fault most times
Bosch 24 in.... | Answered on Apr 23, 2010
Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher Logo
42 questions posted
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch shx99a15uc went completely dead
  • Dishwashers
