There are several things that could be faulty. Have you checked that the old element had actually failed after you pulled it out. Try checking the thermostat, the switch that turns the oven on, and that you installed all the wires back on correctly when you swapped the element. Also check there is power on the oven.
If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
Please rate my soluti9on.
Thanks.
Most of the temp. & select knobs do extend out, but not automatically. If you push the knob inward and release, they should individually "pop" extend out to allow them easier to function. As I indicated this is how most modern bosch work, with the acception of some models. Please provide your actual model number if you require further help.
Hope that answer's you question, let me know if I can assist you further.
Good luck, please rate this solution accordingly and thanks for coming to "fixya".
Macmarkus :)
If you have aBOSCHelectric Cooker or Fan Oven which isnot heating it could be one of the following problems. 1, If thefan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter. To gain access to theBOSCH elementyou will have to remove the back platefrom inside the oven. Once removed you will see the fan andelement,if you look closely at theelementyou will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but theelement is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If yourBOSCHfan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your ovenfan motor is working you willsee the blade turning fast if it is ok. if the element is heating but thefan motor is not blowing the heat into theoven then you need To replace the ovenfan motor is a little moreexpensive and a bit more involved. 3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace yourBOSCHoventhermostat
4, A quite commonand easily overlooked answer is if yourBOSCHoven is not working at all ie: no heatand no fan then the chances are that someone has put the oventimer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO
TUTORIALS1, If the Bosch fan motorin the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter. To gain access to the BOSCHelement you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the elementyou will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine. 2, If your BOSCH fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your BOSCH oven thermostat 4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timerinto AUTO mode,
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Hi!
The location of the thermal fuse in a Bosch single wall oven may vary depending on the model, but it is typically located on the back of the oven.
To locate the thermal fuse, follow these steps:
Turn off power to the oven: Before attempting any repairs, turn off the power to the oven by unplugging it or turning off the circuit breaker that supplies power to the oven.
Remove the back panel: Locate the screws or bolts that hold the back panel of the oven in place and remove them using a screwdriver or socket wrench. Carefully remove the back panel to access the components inside the oven.
Locate the thermal fuse: Look for a small, rectangular device with two wires attached to it. This is the thermal fuse. It may be located near the top or bottom of the back of the oven, depending on the model.
Check the thermal fuse for continuity: Use a multimeter to check the continuity of the thermal fuse. Set the multimeter to the ohms setting and touch the probes to the two terminals of the thermal fuse. If the multimeter shows no continuity, the thermal fuse has blown and needs to be replaced.
Replace the thermal fuse: If the thermal fuse has blown, replace it with a new one of the same rating. Install the new fuse in the same location as the old one and reattach the back panel of the oven.
Test the oven: After replacing the thermal fuse and reassembling the oven, turn on power to the oven and test it to ensure that it is working properly.
If you are not comfortable working with electrical components or if you are unable to locate the thermal fuse in your Bosch single wall oven, it's recommended to seek the assistance of a qualified technician.
Kind regards
first thing I would do is check the cables that go to the clock, if they are OK then you likely have a faulty clock module which will need to be replaced.
Get some epoxy putty, grease the shaft with Vaseline, put a small pea size piece of epoxy rolled thinly and insert it into the knob where the flat part registers on the knob. Push the knob into place and leave it 24 hours to cure.
I use this.
Yes, the tube is fed in from behind or above. Some thermostat bodies have a small adjusting screw to allow you to calibrate if it is fairly close. The videos show it is a simple job.
The issue you're experiencing with your Bosch convection microwave not heating in convection mode could be caused by a few different things. Here are a few things to check:
Check the settings: Make sure that the microwave is set to convection mode and that the temperature and time settings are correct.
Check the element: The bottom heating element is responsible for providing heat during convection mode. Make sure that the element is not damaged or burnt out. You can visually inspect it, if it is damaged it will need to be replaced.
Check the fan: The fan is responsible for circulating hot air during convection mode. Make sure that the fan is not blocked or damaged. If it is, it will need to be replaced.
Check the control board: The control board is responsible for controlling the functions of the microwave. A malfunctioning control board could prevent the microwave from heating in convection mode.
Check for a blown thermal fuse: A thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse is blown, it will need to be replaced.
Check for a blown thermal cut-off: A thermal cut-off is a device that cuts off power to the oven if it overheats. If the thermal cut-off is blown, it will need to be replaced.
